Pictures of your diy Pass amplifier - Page 190 - diyAudio
Old 17th May 2013, 08:19 AM   #1891
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Duh, Conrad...nl
dT = 18.2C , dissipation = 41.5W => Rcs = 0.44 C/W worst case.
For mica, that's actually rather good.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 17th May 2013, 09:06 AM   #1892
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
Originally Posted by WalterW View Post
I've been measuring this and it concerns me... when the amp is around 53C the outputs are around 70C, I even measured 71,2C as max
On average I would say the housings of the MOSFET are around 15 degrees hotter than the heatsink... seems a lot...maybe my mica / silicone paste combi isn't that good.
Though I already splitted the mica insulators twice. So four times thinner than original.
The diodes under the transformers are around 45C, so that's OK.
Hi Walter,
First of all congratulations on a really fantastic build.
As I've working for some months on something very similar and have tested exactly the closed box working temp of the Transistors i have to say...in chorus with master ZM that the first thing that struck me was the small vents top and bottom.
They are in principle not wide enough to permit proper airflow from bottom to top inside the case.
This case topology creats a "tunnel effect" as Patricks calls it because air coming in from bottom of case is directed in font of transistors ( main PCB ) before exiting through top, so wider entrance at bottom and exit at top would probably work better.
ZMs suggestion, already seen here in other great builds would be your easiest fix.
At least easy to try without any panel reworking.
Enjoy a really great build.
Old 17th May 2013, 09:21 AM   #1893
lorienblack's Avatar
Default New build
Not the best picture. The front is an olive chopping board, the volume knob is horn and will ne replaced soon. Heat sinks from Australia.
Old 17th May 2013, 10:30 AM   #1894
EUVL is offline EUVL  Europe
This is a figure which would not surprise me for mica & grease.
I generally can get my MOSFET case to be within 5°C of the heatsink temperature measured next to the FET.
For more details you can download my article on thermal design of Class A amplifiers at Linear Audio (free).
All these issues were analysed in detail in the article.
http://www.linearaudio.net/images/st...%20PK%20lr.pdf
The tunnel effect CeeVee mentioned will only help to lower temperature inside the case between the heatsinks (i.e. your transformer and caps).
It will not solve your MOSFET temperature issue.
If there would be one quick cure then buy some Kerafol from Conrad to replace the mica & grease.
My 2 cents,
Patrick
xen-audio.com
Old 17th May 2013, 10:58 AM   #1895
WalterW is offline WalterW  Netherlands
Originally Posted by CeeVee View Post
Hi Walter,
Thanks CeeVee for the kind words, I will putt spacers between the top lid and chassis. Also for the bottom plate which is a bit harder to do, but thanks to my floating PSU, must be possible.
So you and master ZM think 71C is acceptable ?
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 17th May 2013, 11:30 AM   #1896
Thanks Patrick! That excellent article is already in 'my Documents'
But I'm going to try the Kerafol, and figure out to clamp the FETs, cause I understood the Kerafols perform best under pressure.
The 5 degrees delta you mention sounds a lot better. Just for peace of mind.
I already ordered 16 new matched MOSFET from NicMac from the F5X GB and populate my amp boards with these. So that each MOSFET dissipates around 20 Watts instead of 40 Watt.
My v2 turns into a light v3
Thermal tracking must be improved with the NTC's, I want to build thermal protection on the amp, so that it switches off when sinks get hotter than 60C.
Anti hum must be implemented... So lot of nice work to come
Walter
Old 17th May 2013, 01:41 PM   #1897
If you are referring to those in the First Watt F5 circuit to bias the MOSFETs, then I don't use them.
I rather use a lower bias at room temperature. But that is my personal choice.
You just need to add a thermal switch on series with the power supply.
I would use 75°C directly at the MOSFET case.
Measuring somehwere on a heatsink is not really reliable.
But you will, like me, realise that thermal protection is probably not necessary.
You can just put an ammeter to measure the current, or use a current limit on you power supply (not on the F5 circuit).
It is a much better protection for the FETs.
Again, my 2 cents,
Patrick
xen-audio.com
Old 17th May 2013, 01:50 PM   #1898
CeeVee's Avatar
... think 71C is acceptable ?
No I'm sure 71ºC will go down.
Although Patrick is more precise...as always :-) ...heat transfer efficiency from transistor case to heatsink might be an issue still.
I use mica and goop with great results but Kerafol is better and easier solution...if you can get it.
This is a very demanding amp in terms of thermal management so it is worthwhile to optimize from source on...ie: transistor case on... definitely listen to Patrick :-)
As a sure fire safety measure...make a ZM babysitter...i have one and it sure helps in Lisbon summer.
Moving just a little air works wonders....
Old 17th May 2013, 03:59 PM   #1899
If you want the most gain in temperature reduction then use a slow blowing fan.
Works magic.
Patrick
xen-audio.com
Old 17th May 2013, 04:31 PM   #1900
CeeVee's Avatar
Works magic.
Patrick
That's what i call the ZM babysitter....Patrick.
With fans running at half rated voltage...noiseless!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
