Pictures of your diy Pass amplifier - Page 178 - diyAudio
Old 25th March 2013, 04:12 PM   #1771
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
thanks guys, these are well documented points. actually learning something here
There is an advantage to blowing in is that an air filter can be placed over fan grille to reduce dust buildup as positive pressure is maintained inside cabinet. For dusty environments, this would be preferable at expense of reduced cooling efficiency.[/QUOTE]
" If you're going throu hell, keep going"
Old 25th March 2013, 04:22 PM   #1772
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by xrk971 View Post
only reason
Farmer Hick thinks a fan lasts longer with ambient air going through it, than heated air.
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 25th March 2013, 04:27 PM   #1773
diy newbie
oiphy's Avatar
more like = if you design your case for forced air cooling think about airflow and where you want it if you want to differentiate for some reason in front or back......left rigt... up down... so on.
Old 25th March 2013, 04:29 PM   #1774
You mean instead of blowing hot air out, then suck it back in, out, in, out.....
Old 25th March 2013, 04:42 PM   #1775
flg is offline flg  United States
flg's Avatar
But, Do have a cat in the house, Pusy hair clogs up the filter... And, where are you then. Another waf issue?
Damn them, Just try bein a dog!
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 25th March 2013, 05:02 PM   #1776
diy newbie
oiphy's Avatar
more like sucking out big hole. let different amount of cool air in different places
and guide the flow over the parts need cooling ... excuse my poor english.
Old 25th March 2013, 05:54 PM   #1777
xrk971 is offline xrk971  United States
xrk971's Avatar
What do you care about more? A $10 fan or your $500 (in parts and pieces -not retail assembled value) amp? Seriously though, a ball bearing brushless DC motor designed for continuous operation in these fans will run 7 to 10 years before breakdown.
Old 25th March 2013, 06:01 PM   #1778
Typical Euro engineering itch, setting it up to last 20 years instead of 7-10.
Old 26th March 2013, 09:25 AM   #1779
xrk971.
look at any laptop man. no laptop in this world sucks air out
every fan that is mounted under blows air in. every fan mounted on the top sucks air out.
in almost any case with i front/rear mounted fan, the top lid has no vents, so they will be sucking air out(or one blowing in front and one sucking in the back).
you will not get the hotair sirculation with wents on top(hot air rises). but you also lose the ability to rackmount it.
Old 26th March 2013, 10:54 AM   #1780
xrk971's Avatar
Audio San,
I don't want to argue with you regarding basic thermal management concepts in engineering. And you are wrong, I have several laptops (Dell's) that have fans sucking air out - you can see the blades. They switched to internal fans with use of lower power chips that have heatpipes conducting heat to conveniently placed heatsink at exit of fan shroud internally.
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
