Old 9th March 2013, 01:02 AM   #1721
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
in that case - be sure that either screw is electrically isolated on one ( even better - both ) ends ..... or that your screen-bell is electrically isolated from bottom of case , so you are not having shorting turn through donut itself
wire in windings is also isolated from core , electrically ..... but not magnetically
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 9th March 2013, 02:32 AM   #1722
sakellogg's Avatar
I like the EEK! Means the same in any language.
I'm not crazy, my mother had me tested
Old 9th March 2013, 03:39 AM   #1723
coils is offline coils  United States
heres another option for high VA transformers, a cup under the can. Papa also said... somewhere, that he rotates the can for minimal elecrtromagnetic interference.
Coiler
Old 9th March 2013, 08:11 AM   #1724
NSP is offline NSP  Finland
Hmm... I didn't know that there still are possibilities for the electrical loop when trafo center is "metal free", but now that you say it makes sense with the magnetism and all. Well I have to make myself a nylon bolt then.
Old 9th March 2013, 09:29 AM   #1725
i think i rather would use a metal bolt and nylon washers on the bottom and on the cover(like the ones you find on speaker binding posts)
it can be hard for the nylon bolt treads to hold down the transformer.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 9th March 2013, 12:25 PM   #1726
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by sakellogg View Post
I like the EEK!
I'd wait to say that till I was absolutely positive what it means in Serbian.
(Eek me, Z)
Not so much,.......if it says "ZM" in the corner.
Old 9th March 2013, 02:38 PM   #1727
Great work on the cover! Would the value of such a cover be to reduce stray fields or the transformer's mechanical noise?
Old 9th March 2013, 02:45 PM   #1728
Originally Posted by massimo View Post
without the right tools
A piece of pipe can be bought by the cm/inch.
The lid can be made with a generic electric drill, a metal file, and patience.
Leaves the acetylene & oxygen bottles, and a lighter.
Old 9th March 2013, 03:07 PM   #1729
sakellogg's Avatar
(Eek me, Z)
Uh good point.
Old 9th March 2013, 03:21 PM   #1730
Default Toroid shield
Another option, to preserve the clean looks of the shield. Use a good silicone to bond the shield over/around the transformer. Silver solder a piece of wire or braid to the bottom edge of the shield, and run it to a good chassis ground (or just let the shield "float", ungrounded, if hum is not a problem). Result is a grounded shield, with no bolts/nuts showing in the top, and with no dreaded "magnetic loop" around the toroid core. Voila.
(Now, back to the "photos" in this Pass amp photo thread!.....)
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2013 diyAudio
