#1611 |
I can buy the Kapton several places - I'll keep hunting for the Karatherm. Thanks
Bob M. "Arrange Whatever Pieces Come Your Way." |
#1612 |
The obvious suggesti
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#1613 |
Is there still an active Kerafol seller at diyA ?
(sharing a sheet with a few others, and ask a Euro sucker to send one over from the German RadioShack equivalent, is an alternate solution)
Not so much,.......if it says "ZM" in the corner. |
#1614 | |
I got enoug to spare...
#1615 |
Not dissipates heat better the pads of aluminum oxide Fisher or Aavid?
I use Aavid and there is much improvement in temperatures ... 4180G Aavid Thermalloy | Mouser |
#1616 | |
Warmtegeleidende folie Keratherm - Rood 86/82 Kerafol 86/82 (l x b) 100 mm x 100 mm Dikte 0,25 mm 6.5 W/mK in de Conrad online shop I think that's what is mentioned in the article Jacco posted. (from EUVL) BTW: nice article, Jacco ( and Patrick of course!) |
#1617 |
Patrick is The man.
#1618 |
Wow ! Lots of good choices. I'll check them out and report back on my selection. Still leaning toward a 1 mil thickness but that's not an absolute.
Thanks All ![]() Edit: Don't know if I mentioned but another reason I am interested in the film (in a sheet) is use on larger surfaces. The pic is of a TDA7294 project that has a 3 1/4" X 1 1/2" common area. I'm still working on the liquid cooled discrete application which would require as much as a 4" X 11" contact pad. So cost also has to be considered. Simple grease might work but adding the thinnest film could assist the distribution over such a large area. Don't know yet.
Bob M. "Arrange Whatever Pieces Come Your Way." Last edited by bcmbob; 16th February 2013 at 11:56 AM. |
#1619 |
Would you like me to show you a 4" x 4" mica sheet ?
(I've tried almost every plastic sheet variety, in close to 25 years. AlOx insulators from 3mm to 1.5mm, see my diamond blade artwork at the Krell thread. NO more, end of the line for me)
Not so much,.......if it says "ZM" in the corner. Last edited by jacco vermeulen; 16th February 2013 at 12:38 PM. |
#1620 | |
Speaker grounds are taken from amp PCB. From PS ground(floating), wires go to earth ground isolator and amp board. |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Naked pictures of Pass | Pete Fleming | Pass Labs | 30 | 9th December 2006 06:39 AM |
| My new hifi amplifier (pictures) | Wejp | Chip Amps | 23 | 15th October 2004 12:16 AM |
| Pass Diy High Low Pass Please | macka | Pass Labs | 127 | 2nd March 2004 11:00 PM |
| DIY Pass labs 100watt amplifier. | microwalsh8504 | Pass Labs | 12 | 6th February 2004 07:27 PM |
