Pictures of your diy Pass amplifier - Page 157 - diyAudio
Old 31st January 2013, 01:53 PM   #1561
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
It also wasn't intended to be negative, Bob.
Fun has no rules, it's whatever anyone makes of it.
For completeness I felt to add for those who might consider a heat exchanger build themselves, that in most cases it's more expensive to DIY one, plus that the one as-is has several elementary flaws.
President Dwayne Camacho says you should drink Brawndo : It's got electrolytes
Old 31st January 2013, 02:06 PM   #1562
buzzforb's Avatar
Bob,
If he being mean, just stomp his foot
...Shape the sound , Man!
Old 31st January 2013, 02:16 PM   #1563
bcmbob is offline bcmbob  United States
Originally Posted by buzzforb View Post
Bob,
Not a problem. I'm actually happy to learn custom sizes of that style of water block are available. Jacco, I used to buy lots of stuff from McMaster and will check it out.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 31st January 2013, 02:25 PM   #1564
Eric is offline Eric  United States
Eric's Avatar
Originally Posted by Earthloop View Post
Hoping to build a B1 buffer next but I was wondering if anyone knows,
A) What is the input sensitivity of the A40 for full output,
B) Can the amps run with approx +/- 40V rails (my transformer secondaries are 25V and I have replaced the JFET with 2N4392,
C) Could the output stage bias be increased to 2 amps. My speakers are 4 ohms and the A40 will move into class AB at 20 watts into this load.
Earthloop, it's great to see a new a40 build! This was my first amp project - mainly due to the PDF that was available at the PassDIY website when I started. Most of my efforts for the a40 are documented here.
I can make a stab at some of your questions. I do recall measuring input sensitivity for the a40 at some point, but I cannot find where I made my notes. I tend to recall it take about 1.8v to hit full output. I have a clear memory of getting 52w into both a 4-ohm and 8-ohm resistive dummy loads.
As for increasing rail voltage, the only problem that I can see (and maybe I'm missing something) is that the 2N5248 FET is limited to 30v. Replacing this with higher rated part should prevent problems. I don't really see this as a problem for you, though. Your transformer has 25v secondaries, so you should only see rail voltage of about 35v. My transformer has 24v secondaries and I get ~32v rails...
Output bias can be adjusted as well. See the table at the bottom of my a40 page. I experimented with several values for R11 and the resulting bias level. I remember Nelson stating somewhere that the bipolar output devices are most linear and sound better when their bias is kept below 1.0A each. My amp is biased at about 3.2A per channel, so each output transistor runs at about 0.8A bias.
Overall, my A40 runs on 32v rails, 3.2A bias per channel, and produces a pinch more than 50w of output. The input sensitivity is greater than my Aleph-X amps and the a40 can comfortably drive my power hungry Avro speakers to satisfying levels in a large room. I think you'll be happy with yours when it is completed!
Eric
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Old 31st January 2013, 06:06 PM   #1565
Bob,
Jacco wasn't being mean, Buzz... he was just giving us his best AndrewT impersonation
Old 31st January 2013, 06:15 PM   #1566
I'll have to try harder, you're still laughing.
(my left foot, please)
Old 31st January 2013, 06:42 PM   #1567
Old 31st January 2013, 07:06 PM   #1568
buzzforb's Avatar
Wouldn't go that far. It was just an easy OT shot.
Old 31st January 2013, 07:14 PM   #1569
It's been a fun and funny morning, but I would also welcome some candid comments about the cooling technique itself. I'm going to play through at least to the next phase, but all comments both pro and con are welcomed and encouraged.
If this thread isn't exactly the proper place for the topic a new one could be started if there is any interest.
Bob M.
Old 1st February 2013, 02:14 AM   #1570
IMO bcmbob, this topic (and your efforts) DESERVES its' own thread. It would be more easily found in a search that way.
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 11:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 07:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 01:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 3rd March 2004 12:00 AM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 08:27 PM
Copyright ©1999-2017 diyAudio
