#1531 | |
One thing that many will appreciate is the addition of P3, which due to inattention on my part was not public until recently. It allows the adjustment of the distortion character between complete nulling of the second harmonic distortion to an arbitrary ratio of second to third harmonic. It definitely alters the sound, and reaffirms that things going on below 0.1% are audible. In any case, you can adjust it to taste. Did you try that? |
#1532 |
HI ,Les escribo desde chile , les muestro mi primer ampli zen del sr Nelson.pass
esta en una etapa primaria |
#1533 |
english please
![]() moderation |
#1534 | |
Norb
What a build. The case looks very solid. I noticed after a few days of listening that the F5T sounds a little bright with my Thiels. Despite the hum from the pre amp, it does sound very good. As I have replaced all the coupling caps with Jensens, it has that characteristic mellow sound, which I like. I read that the B1 is very neutral so I am not sure whether it would fit my gear and listening taste. Thanks for the suggestion and sharing. Really great work in routing all the wires. TC Quote:
#1535 | |
I read this in the Pass manual too :-). However, I haven't tried adjusting yet. From my recollection, even harmonics are 'good' and should improve the listening pleasure. However, I am not sure if my ears are as sensitive as Nelson's.
Anyway, the amps sounds so good currently .... why mess around with something that is already perfect, right !!! ![]() Bridge mode is the way to go. The sound really opens up and bass extension is ... well .... out of this world. ![]() Hey, is speaker protection using the upc1237 realiable? Any one using these successfully? How do the relays affect the sound? Oh ... I need to rush as I am F5T'ing.... ha ha... even harmonics and all .... TC Pass'ian Quote:
#1536 |
#1537 |
#1538 |
Dear TC,
maybe the A75 would be an option for you, as you can alter the sonic characteristic of this amp in a large range. I tried different values for some components as suggested in the A75 article (feed-back amount and folded cascode operation) and the amp could be made very mellow and softly sounding (Speakers are Isophon Europa). Since i´m more the rocking kind, i set up the amp in the opposite soundwise, but the difference in sound characteristic was amazing, espacially voices and classical music could be made like honey: sweet, soft and golden. Norb |
#1539 |
May I ask why?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#1540 |
Allen Wright was talking about Time Smear
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Naked pictures of Pass | Pete Fleming | Pass Labs | 30 | 9th December 2006 06:39 AM |
| My new hifi amplifier (pictures) | Wejp | Chip Amps | 23 | 15th October 2004 12:16 AM |
| Pass Diy High Low Pass Please | macka | Pass Labs | 127 | 2nd March 2004 11:00 PM |
| DIY Pass labs 100watt amplifier. | microwalsh8504 | Pass Labs | 12 | 6th February 2004 07:27 PM |
