#1401 |
Hi Marra,
You know the wood working was the easy part. Dovetail are not hard to do if you are patient. Alex |
#1402 | |
is choosing a less facetious title...
it would be better if we were able to attach, but inline in text body; this is much more useful than just in a group at the bottom, particularly for tutorials. presently, unless things have changed; I think the only way you can do that is if linked from an external host. if attached afaik it always must be in a group at the bottom of the post. so if there could be a limit of file size/visual size, but also allowing inline images this would be ideal IMO
#1403 |
ZM -
If you wait, the board will automatically resize the pics and present a smaller thumbnail. It takes usually a couple of hours. Then you can still click into the really big pics if you care to. It always seems to do that to my photos, but I try not to post anything wider than about 600 or so.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - - Pass F4 Last edited by 6L6; 15th October 2012 at 10:31 PM. |
#1404 | |
im kidding. very nice. something to strive for, on my end. wow, i wish i could do that.
I'm not crazy, my mother had me tested |
#1405 |
Alex - In the first image of your chassis, I'm looking at the shiny square next to your power supply caps that looks like a bridge rectifier. This method of mounting the rectifier will cause it to overheat and fail. The case of the rectifier is metal and needs to be attached to a heat sink in order to dissipate heat. It may be that you have already purchased a sink to attach to the top of your rectifier, in which case there are no worries.
But, as pictured, you are set up for a problem in the near future. You might even want to move the rectifier off of this board and directly attach it to one of main sinks for your chassis... Eric
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages. |
#1406 |
#1407 |
When I use one its a TENDON saw!
Skill I don't have it
#1408 |
Today I start using my new amp;
I allready showed it on a separate thread but I posted a preview here a while ago. In the future I will give it a nice finish here; 8 Channel Amplifier and here; several Aleph's in one big case
I hate carryable |
#1409 |
HOLY HEATSINKS AARON !!!
How many HEATSINKS is that... ...A LOT !!! I guess the dolly is removed as the crane lowers it into position, on the RSJ reinforced floor. Oh well... ...If you can't carry it...WHEEL move it somehow !!! Cheers Si. |
#1410 |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Naked pictures of Pass | Pete Fleming | Pass Labs | 30 | 9th December 2006 06:39 AM |
| My new hifi amplifier (pictures) | Wejp | Chip Amps | 23 | 15th October 2004 12:16 AM |
| Pass Diy High Low Pass Please | macka | Pass Labs | 127 | 2nd March 2004 11:00 PM |
| DIY Pass labs 100watt amplifier. | microwalsh8504 | Pass Labs | 12 | 6th February 2004 07:27 PM |
