Pictures of your diy Pass amplifier - Page 119 - diyAudio
Old 13th April 2012, 05:48 PM   #1181
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Eric, looks good. What wood is the front panel?
Does the wood get hot? Is it isolated from the heat sinks?
I'm making a wood front panel for a Zen 9 this weekend.
I build, therefore I am.
Old 13th April 2012, 06:00 PM   #1182
Eric is offline Eric  United States
Eric's Avatar
Hi Vince,
Its a 1" thick multi-layer ply with a real wood veneer. The heatsinks are bolted directly to the side panels - no additional isolation or spacers were used. There are multiple holes drilled in the bottom panel and the top panel is hinged for easy open. The hinges and and felt pads where the top panel rests provide some "elevation" to the top panel so it does not close tightly on the four sides. Thus, there is an air gap of about 1/4" all of the way around the top to let heat from the transformer/rectifiers to escape. Here is a better picture of the sinks.
The wood chassis does get warm, but typically stays close to body temperature - 100F. From time to time, I've thought about adding a copper/aluminum plate to the underside of the top panel just above my DIY heatsinks for the rectifiers, but I've never gotten around to it. The wood is very slightly more dried directly above the rectifiers - you can see several small cracks in the surface if you look closely, but it doesn't cause any concern for me.
Hope this helps!
Eric
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Old 13th April 2012, 06:11 PM   #1183
vdi_nenna's Avatar
Yes, it does. Thanks.
Old 22nd April 2012, 03:02 PM   #1184
My dual output F5. My first attempt at amplifier assembly. Thanks to the information on this forum, it worked first shot and sounds better than I deserve. Heatsink at 50 degrees with case open and drain of mosfet at 63 degrees (fluke thermal probe).
F5 - a set on Flickr
Old 22nd April 2012, 03:09 PM   #1185
Abraxas336's Avatar
Nice. How does it compare to the Ncore?
Gruenschnabel
Old 22nd April 2012, 03:23 PM   #1186
Thanks. As I've just finished the Ncore, not had much time to listen yet. First impressions are that the F5 is slightly warmer sounding. Will report back when I've spent more time with them.
Old 22nd April 2012, 03:31 PM   #1187
Marra is offline Marra  United Kingdom
Is that a Claro Dual on top?
Old 22nd April 2012, 03:39 PM   #1188
Claro 09. It was a special version made for me with taller platter and a bespoke mounting for the SME V. I use a Nottingham Analogue Wave Mechanic with it and it sounds brilliant. With the Koetsu Rosewood it sounds better than the Xmos/BuffaloIII/Legato 3 digital front end in my system:-).
Old 22nd April 2012, 05:55 PM   #1189
fdlsys is offline fdlsys  South Africa
fdlsys's Avatar
Originally Posted by vanwykca View Post
My dual output F5. My first attempt at amplifier assembly...
Beautiful work Cornelius! Congrats.
If I may ask - what are those rectifier bridges that you are using, and the slow-start circuit?
Old 22nd April 2012, 06:07 PM   #1190
Thank you. The rectifiers are IXYS Fred 68A 600V bridges
http://www.partsconnexion.com/PDF/l363.pdf
and the slow start is the SSM module from Avondale Audio
soft start electronics for audiophile hifi audio amplifiers : avondale audio
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
