Pictures of your diy Pass amplifier - Page 102 - diyAudio
Old 6th January 2012, 12:46 AM   #1011
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
6L6 thanks....your build guide was a nice reference to have as I built my amp. Very well documented. Your time is appreciated.
Evan
http://www.evancotler.com
Old 6th January 2012, 12:52 AM   #1012
mhouston's Avatar
evanc: Mate very nice job. It better sound good.
Old 6th January 2012, 01:33 AM   #1013
Originally Posted by evanc View Post
here it is my freshly minted f-5. Thanks to Mr. Pass for this design, and all that have posted before me who answered my questions before I had them.
Nice!! Only think be careful not to cook the caps. It will be hot inside, as there is no ventilation. I had to make holes in summer. You can make a "summertime" cover :-)
D.
Old 6th January 2012, 01:39 AM   #1014
3GGG is offline 3GGG  Australia
Beautiful work, but i worry about Class A and wood
Old 6th January 2012, 02:03 AM   #1015
I have a thermometer in the case as we speak. Less then 100 degrees F. The wood will certainly not catch fire...as far as the cap go I'm not sure what is OK.
Mhouston, yes it sounds good, but I am only a trained monkey.....
Old 6th January 2012, 09:22 AM   #1016
dvb projekt's Avatar
Chapeau!
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 6th January 2012, 09:51 AM   #1017
KatieandDad's Avatar
I certainly found with my Aleph 4 that it would run beautifully cool in the winter with temperatures inside the case at about 45 degrees C. However, in the summer the internals would run at closer to 55 degrees.
The simple solution was to fit a pair of 50mm fans (12V) but running them in series. The result is virtually silent and the temperatures keep the caps well below 50 degrees C.
The fans are above the cap banks with large holes drilled in the base around the caps.
Old 6th January 2012, 10:07 AM   #1018
reytnz is offline reytnz  New Zealand
reytnz's Avatar
Just finished my F5. Thank you Mr. N. Pass and to DiyAudio for sharing this Brilliant amplifier.
Old 6th January 2012, 10:59 AM   #1019
Mixon1 is offline Mixon1  Sweden
Real nice! Well built!
Old 6th January 2012, 12:55 PM   #1020
reytnz,
That is super neat. I have a long way to go before something I build looks that good on the inside.
Evan
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 11:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 07:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 01:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 3rd March 2004 12:00 AM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 08:27 PM
Copyright 1999-2017 diyAudio
