Pictures of your diy Pass amplifier - Page 100 - diyAudio
Old 1st January 2012, 05:58 PM   #991
mhouston's Avatar
Originally Posted by merlin2069er View Post
Here's a little jfet boz I quickly slapped up together. I think I should use a shielded cable on the input. I'm going to use an external battery pack (2x 9v).
I think if you can avoid shielded cable do. I very rarely use it. You should not need it as all signal voltages entering the preamp should be better than a volt or two. Earth the case if you get hum. I power some of my BoZi on batteries but I have a very simple external supply made from a 24VAC wall wart. I rectify and lightly filter the power external to my BoZ (in this case my BoZSE). It does require that you have at least 20,000uf of storage cap on your BoZ cct.brd. as I do (BoZSE - 30,000uf). This is part Hiraga and Pass design to have this much storage directly on board.
Using the external DC PS means only DC (though only lightly filtered) enters the BoZ. In the PS I use a 10uf poly after the rec. bridge then a 680ohm resistor (can vary) then 1000uf low ESR cap.
Old 1st January 2012, 06:32 PM   #992
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Thanks for the suggestions.
How do I go about earth grounding the case? I use a 24v dc walwart (currently) and there is some hum.
Old 1st January 2012, 09:34 PM   #993
mhouston's Avatar
Remember there is DC going into the case. Take the negative of the PS and attach to the case. Usually the the negative (non-hot) wire of RCAs attaches to the case too unless you used isolating RCAs. I often use isolating RCAs because they look better then ground the negative of the RCA to the case.
Some like to use a 100ohm resistor to ground the negative of the PS to the case and some also by-pass this with a small cap.
Old 2nd January 2012, 03:27 PM   #994
Gregje is offline Gregje  United Kingdom
Hi Guys,
You have plenty of very nice constructions in this thread. What about some more humble approach;-)
The monoblocks are Zens. The PCB to the left is BOZ.
Greg
Old 2nd January 2012, 04:38 PM   #995
norb is offline norb  Germany
my sweeeeet little A75
Old 2nd January 2012, 04:50 PM   #996
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Norbert, great fun to see the final outcome of your A75 endeavour.
(even your rectifier diodes are uncommon)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 2nd January 2012, 09:11 PM   #997
mhouston's Avatar
merlin2069er: what are your output caps in your BoZ? I don't use input caps only output caps.
Old 2nd January 2012, 09:14 PM   #998
Preamp is offline Preamp  Germany
ulti.preamp.org
Preamp's Avatar
Norbert, nice heatsinks! Were they salvaged from an old thyristor bank?
Old 2nd January 2012, 10:46 PM   #999
Here's a close up of the jfet boz ... I bought these caps on ebay (paper in oil) from vintage audio lab.
Old 3rd January 2012, 12:10 AM   #1000
mhouston's Avatar
Nice caps. Your build is almost a BoZoaC.
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
