Pictures of your diy Pass amplifier
Old 25th October 2011, 12:55 PM   #901
taniknight is offline taniknight  Australia
taniknight's Avatar
Originally Posted by blistard View Post
I am still searching for an appropiate phono-preamp to include. Any suggestions (preferrably an FET-design of which an PCB-design is available) ?
I have built the NJFET phono pre by Salas and I can say that even with modest components and on perfboard it performs very well, as many other builders would agree. The thread is long but there is a PDF summary (actually there are a few) that covers all the basics. Check Salas's evolution/update link on the first post to take you to the latest "basic" version of the circuit.
Salas also has a shunt reg that is recommended.
Both have single sided PCB files around too.
Tani.
Old 26th October 2011, 03:36 AM   #902
dionisio is offline dionisio  United States
dionisio's Avatar
Thanks for the kind words everyone..
Originally Posted by westend View Post
Nice work, Dionsio! Can you comment on the heat dissipation? If your design handles the standard heat dissipation, future builders could save the cost of extruded heatsinks.
FWIW, I use one of these Amana non-ferrous blades for aluminum. The triple chip and negative hook angle leave a mirror fine edge.
I cant tell you exactly what the temp is as I dont have a IR thermo. I did run it for 8hrs biased at .65 and the whole case was cozy warm to the touch, not uncomfortable at all.. When I touched the mosfets they felt about the same temp as the case.. So far so good.....
Thanks for the tip on the blade
Originally Posted by vdi_nenna View Post
Nice work, Sean.
Nice to see someone finally make that style of case.
Where did you pickup the tubing and did you use any thermo grease between the tubing and sidewalls?
Thx,
Vince
The tubing came from Online metals.com
Yes a thin line of thermal grease squeezes out nicely when the tube is tightened down
Old 29th October 2011, 04:44 PM   #903
jazz is offline jazz  Netherlands
Default CAS-1 clone
below is the first mock build of the Cas-1 clone i'm building. It works sofar and sounds promising.
Joris
oh, what a beautifull day
I wanna go out and play!
Old 3rd November 2011, 11:47 AM   #904
adwsail is offline adwsail  United States
Default A Different Zen V9
After smoking my V9 circuit a couple of years ago I tried again and this time it worked so I made a decent case for it.
Old 3rd November 2011, 12:00 PM   #905
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
extremely Fugly!
(it will be twice that , if you post proper resolution porn )
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 3rd November 2011, 12:21 PM   #906
udailey is offline udailey  United States
And he did the whole thing with a table saw! LOL
Man that looks absolutely beautiful. You are quite an artist.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 3rd November 2011, 12:52 PM   #907
Atilla is offline Atilla  Norway
"Decent" - a word that'd be at the bottom of the scale of possible descriptions for what you've done. Wow ...
Give us Hi-res shots, pretty please, with sugar on top!
Old 3rd November 2011, 12:57 PM   #908
6L6 is offline 6L6  United States
6L6's Avatar
Yes. I concur! That's a wonderful creation and bigger photos are necessary!
Old 3rd November 2011, 01:47 PM   #909
What resolution is appropriate for this forum?
Old 3rd November 2011, 01:49 PM   #910
R.I.P.
The restrictions are very lax.
There is a Thread about downloading appropriate sized pics.
It depends on the detail you want us to see.
regards Andrew T.
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
