Pictures of your diy Pass amplifier
Old 27th February 2018, 08:13 PM   #4251
MASantos is offline MASantos  Portugal
[QUOTE=WalterW;5355065]
Originally Posted by chermann View Post
...sorry...i hope it is no secret...
it looks very similar to yours ]
Yep that's the one, there are different sellers on ebay and aliexpress.
I bought from ebay. Only 126 euro a piece. but with 60 euro shipping.
When the chassis arrived I had to pay an additional 65 Euro taxes
So almost 250 Euros for this chassis.
It's a very good looking chassis, but quite a lot more than the equivalent modushop chassis. it looks so much better though...
Old 28th February 2018, 06:51 AM   #4252
chermann is online now chermann  Austria
Sorry for you Walter...but i know...... i paid for my caps delivery (3xSMPS and some audio caps) 35 euro extra tax fee ...so i know the tax fee is a horror.
Old 1st March 2018, 10:05 PM   #4253
culture is offline culture  Netherlands
Originally Posted by Rodeodave View Post
Case stack for some upcoming builds
Hmmm... Yeti!
Old 8th March 2018, 09:28 PM   #4254
mns80 is offline mns80  Finland
Default A go at BA-3b + BA2 (nicknamed Overkill)
I started already in 2012 doing some calculations, drawing the pcbs and ordered the Toshiba FETs and heatsinks. However the build has stood still for most of the time due to other activities since then.
Late 2016 i started again with renewed enthusiasm and got to listen to the sweet sounds of this combo the first time in beginning of June 2017. I have only adjusted the gain in the BA-3b after that. Added a switch last week to have a low and high setting, high is now at about 33dB. Did not measure low but it is a lot lower.
The two BA-3b shares a box with the volume pot, a 4 gang motorized ALPS RK27, remote control card (cheap ebay thingie), relay card for inputs (2rca, 1 xlr, 1 phono) and a Salas simplistic riia. In the box under is the powersupply for the previously mentioned equipment. There are 6pcs simplistic Salas shunt regulators v1.2R packed into the box. 2x +30V, 2x-30V for the BA-3b, 2x +24V for the riia and just a rectifier and some capacitors for the controlboard. There is also a slowstart included for the two transformers. The boxes are from Modushop with 10mm front panel and sheet metal lid and bottom. Power supply box has heatsinks along the sides for the shunts and upper box is just plain sheetmetal.
The BA2s weigh in at 59.5kg each with 22kg of heatsinking, 10mm aluminium lid, mid platform and bottom and a sturdy frame of 20mm solid aluminium. Everything tapped and bolted together with 6mm screws. Three sides are made of plexiglass to show off the inside. Everything is on wheels so it is easy to move around when necessary.
Transformers are 2x21V 2000VA from toroidy.pl, Epcos 40V 100000uF capacitors in a CRC configuration giving 27V rails. 12xIRF240 and 12xIRFP9240 per monoblock biased at 600mA a piece.
Temperature on mosfets are around 60 degrees celsius. Slowstart is included, limited to 6A now if I remember correctly.
Finish is still open, would be fun to anodize the aluminium parts some time.
Hope I got this in the right thread this time
Old 8th March 2018, 09:40 PM   #4255
NicMac is offline NicMac  Italy
NicMac's Avatar
I love the transparent acrylic plates - to show of your good work without disassembling
Old 8th March 2018, 09:45 PM   #4256
Soundhappy is offline Soundhappy  France
Soundhappy's Avatar
Do Your amp have some air flow inside or is close box ?
Anyway congratulations
class A amplifiers with full range speakers
sings like angels in heaven
Old 9th March 2018, 03:39 PM   #4257
Thanks!
I was first thinking about real glass but it was kind of expensive so I went for the acrylic.
Air flow inside the box is very limited, there is a small gap between the top and bottom and the sinks/acrylic but I do not think it does much for the airflow. during the build I was thinking that I can cut some holes in the bottom plate and increase the gap a little on top in case the temperature rises too high to get some airflow.
Old 23rd March 2018, 11:35 PM   #4258
Joschl is offline Joschl  Germany
Joschl's Avatar
F3 in scrap metal enclosure...
The heatsink came first and the rest developed around it.
Old 23rd March 2018, 11:38 PM   #4259
6L6 is offline 6L6  United States
6L6's Avatar
Beautifully done! My favorite constructions are those made from parts on-hand and found.
Congratulations!
Old 23rd March 2018, 11:50 PM   #4260
Joschl's Avatar
Thanks!
The final assembly of the mains wiring and isolation isnít finished yet. Also the mechanical part of the second amp is waiting on the bench in the basement.
And I still ponder on how to do the frontPictures of your diy Pass amplifier
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
