Pictures of your diy Pass amplifier
Old 24th August 2010, 11:50 AM   #231
Andy5112405 is offline Andy5112405  United Kingdom
Banned
I'm surprised at your choice of capacitors for a Class A amplifier.
I'm using 12 x Dubilier Computer Grade 33000uF / 75V caps which actually test at nearly 90000uF each. This gives me approximately 300000uF per supply rail and nearly 150A of ripple current. I bought them on E-Bay from the US and paid about £6.00 each for them.
Old 24th August 2010, 11:54 AM   #232
Melon Head is offline Melon Head  Australia
Banned
Nelson is happy using Panasonic tsha. So I am happy using Nippon Chemi-Con KMH.
On top of that I got them very cheap (less than a dollar each).
Old 24th August 2010, 11:56 AM   #233
Banned
In my first prototype, my heatsinking was just completely inadequate and I cooked the output devices on one channel.
This case has now been scrapped and the components re-used.
Old 24th August 2010, 11:59 AM   #234
Banned
Personally I would just check the maximum ripple current. Computer Grade Caps are generally HIGH ripple.
There is a very good argument for using LOTS of smaller caps. I've seen a Gain Clone project with over 100 x Black Gates.
I'm using B&W speakers which do require a high current drive, therefore my PSU is designed to give just that. In the Aleph 4 I can happily peak over 150A if the situation desires it.
Old 24th August 2010, 12:49 PM   #235
Banned
I do not remember the specs of the Aleph 4 but I am almost certain the Aleph current source would be lucky to deliver 20A/channel (in the Aleph 4) let alone 150A.
If you had a push pull output stage then that is a different matter (eg BA2). From memory the Aleph current source is limited to around twice the bias current. Eg If the bias current is 4A then the maximum output the Aleph current source will deliver is around 8A (could be a bit higher).
Obviously you could tweak the Aleph current source to put out a higher dynamic current, if that is what you wanted to do.
Old 24th August 2010, 01:07 PM   #236
Banned
Just cheked the data sheet. The ripple current is 5.39A per cap.
I am not sure how many I will use at this point in time. It will come down to listening tests.
I have 24, so I could use up to 6 per rail per channel (if I decide to go monoblock).
In the end the ear will decide.
Old 24th August 2010, 02:36 PM   #237
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Andy, your amp in picture looks real nice
yet, a small note about transistor mount
transistors should ideally be mounted around middle of heatsink, or even better right below, vertically
to me it appears like you have them very close to top of heatsink
sometimes we know very little, and sometimes we know too much
Old 24th August 2010, 04:04 PM   #238
LucasAdamson is offline LucasAdamson  United Kingdom
LucasAdamson's Avatar
Aren't there also arguments for not using an unlimited number of caps? In chip amps, which require less power smoothing, it is quite common to use as little as 4,000uF per channel, the argument being that it increases the audible speed (immediacy) of the amp without losing bass. Obviously that is a different situation, but isn't there an argument to say that too much capacitance might slow a Class A amp down?
Lucas
Old 24th August 2010, 04:08 PM   #239
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Opamps generally have a much better PSRR than Class A amps if my memory serves me correctly. Therefore requiring less capacitance.
Old 24th August 2010, 04:10 PM   #240
I would rather suspect that about very big supply caps, and Im not sure its only related to capacitance
Though, with classA, if caps are under rated they might get VERY hot
I doubt there are any simple single answers to that
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
