Pictures of your diy Pass amplifier
Old 6th July 2013, 08:28 PM   #2081
WalterW is offline WalterW  Netherlands
Default Finished F5T v3
Finally finished the v3.
It's exactly build according the Nelson Pass circuit except for the (better?) Toshiba MOSFETs in the output stage.
In the version 2, I biased the MOSFETs at 1,25 A @ 32V, which resulted in very hot MOSFETs. Around 70 degrees Celsius.
Now I've doubled the output devices, so half the current for each device, and used Kerafol instead of mica and goop. Also clamped the output MOSFET's and yes, now I have only 5 a 6 Celsius difference between the heatsinks and the output devices.
Kerafol 86/82 under big pressure rocks !
Heatsinks max out around 58 C with 0,225A per rail bias and the MOSFETs are around 62 C.
Can't use 2.5 A bias per rail since my T ambient is around 25C this time of year
I also implemented a thermal protection by glueing 75C switches on the Toshibas.
Didn't need too implement C3 and C4 for stability.
The amp is dead silent, and it sounds so great !
During the rebuild to a version 3, I constantly listened to my standard F5 ( which isn't bad!) but this v3 has definitely more body, bigger soundstage, more bass and sounds a bit more detailed and relaxed, yes.
Attached are my last pictures for this project.
Now it's time to build a set of high end speakers... suggestions are welcome...
Although I already ordered the ACA PCB's and the beautiful red chassis for a little desktop computer class A Amp ( or maybe for my son) , I must say the Aleph J pre-order PCB's in the store are tempting
Would like to hear how a single ended class A will sound
Walter
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 6th July 2013, 08:43 PM   #2082
ijscobar is offline ijscobar  Netherlands
Banned
One of the Jenzens from Troels Gravesen. I heard the Jenzen ER: it's magnificent. I am currently building the Jenzen NEXT and if you wish there are even Higher End Jenzens :-)
Old 6th July 2013, 09:12 PM   #2083
lanchile is offline lanchile  United States
lanchile's Avatar
Walter...your amp looks very nice! Hats off to you
Make it simple...Make it better!
Old 6th July 2013, 09:14 PM   #2084
Thanks ijscoman
Will have a look at it, on his website. Been there before and was very pleased with his designs...
Walter
Old 6th July 2013, 09:49 PM   #2085
PKI is online now PKI  United States
PKI's Avatar
http://www.troelsgravesen.dk/cyclop.htm
http://www.troelsgravesen.dk/JA8008_DTQWT.htm
Old 6th July 2013, 10:10 PM   #2086
Originally Posted by PKI View Post
Thanks! Those cabinets are difficult to build...for me, a starter...only built a quite big subwoofer so far...
Old 6th July 2013, 10:22 PM   #2087
pcb121055 is offline pcb121055  United States
Great looking build! Nice work
Old 6th July 2013, 10:38 PM   #2088
labjr is offline labjr  United States
That is nice. I noticed you have an ebay soft start module. Does that one work well?
Old 6th July 2013, 10:49 PM   #2089
Triodethom is offline Triodethom  United States
Triodethom's Avatar
Very nice where the chassis come from ?
Old 6th July 2013, 11:10 PM   #2090
duder1982 is offline duder1982  United States
duder1982's Avatar
Walter
very good, nice to see a completed unit. Especially using teabags boards. Hopefully your build along with others, will help people like me along their path of building something similar.
If I cant build it or fix it I really dont want it.
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
