Pictures of your diy Pass amplifier
Old 24th June 2013, 10:10 PM   #2031
12B4A is offline 12B4A  United States
12B4A's Avatar
Originally Posted by 6L6 View Post
The only thing I would change is to flip the schematic so the output is on top.
Nice, that does make it look better.
Old 25th June 2013, 08:31 AM   #2032
on the underside of the lid?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th June 2013, 11:34 AM   #2033
AudioSan is offline AudioSan  Norway
engrave it on a piece of plexi. and light it up with LED's
Old 25th June 2013, 11:41 AM   #2034
12B4A's Avatar
Nah, it would be on the front face of the unit. The intent is to make a faithful visual representation of the circuit but smooth some of the edges with some abstraction.
Originally Posted by AudioSan
engrave it on a piece of plexi. and light it up with LED'sClick the image to open in full size.
Not if I can't make them multicolored and blink.
Old 25th June 2013, 11:47 AM   #2035
yes. a plexi piece on the front With schematics engraved. and LED's light up the engraving. that would be awsome
Old 26th June 2013, 07:35 AM   #2036
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by bcmbob View Post
Asus motherboards have a feature called "Cool & Quiet" that will start the fan low and increase the speed as the system temps get higher. I'm not sure how sophisticated that technology on the MB is.
A simple circuit that tracks fan speed to water temperature shouldn't be very complicated. As water temperature goes up so it does fan speed.
Thermo-Fan to keep your amplifier cool
"The temperature is set with VR1. Operate the amp until the normal temperature is reached, then adjust VR1 until the fan starts. Then back off very slowly until the fan stops again. Any increase over the normal temperature will start the fan, and promptly bring the temperature back down again."
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 26th June 2013, 12:30 PM   #2037
bcmbob is offline bcmbob  United States
A couple mods and replies on the F5 cooler HERE.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 27th June 2013, 04:22 PM   #2038
12B4A's Avatar
Here's my attempt to visualize my idea. I dunno, there's something missing. Maybe it would look better with handles.
Old 27th June 2013, 05:58 PM   #2039
overtheairbroadcast is offline overtheairbroadcast  Canada
It is a nice idea and it will probably work, but try this as an alternative (maybe you can mock it up like you did with the one you pictured): place the diagram/etching on the top cover/plate.
I have seen diagrams/info/scripting done on various amplifiers before, kind of like the wiring instructions you find on the top of a McIntosh MC205 (SS) cover or the MC275 (tube) transformers.
Old 27th June 2013, 07:19 PM   #2040
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
I don't think you should flip the diagram on its side, nor use the concentric arcs at input and output (see the sine wave NP uses to indicate larger signal), nor use some non-standard potentiometer-looking connection (with the arrow) to the V rails. Keep it as standard as possible...
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
