Pictures of your diy Pass amplifier
Old 18th June 2013, 09:59 PM   #1981
bcmbob is offline bcmbob  United States
Here are some photos of the latest attempt to combine computer liquid cooling and power amps. This one is performing far beyond expectations. I jokingly have dubbed it the “flush”, as it based on the same principle as the drain tube in the water tank off a ...umm water closet. Great credit goes to XRK971 here on the forum – he informed me that water has an enormous heat adsorption capacity – far beyond any metal. Many thanks Mr. X.
I selected a 1” X 1” X ¼ aluminum tube because of it's natural heat absorption and it also allowed comfortable margins to use threaded 6-32 bolts on the ends. Every attempt to use blind holes where possible was made to avoid leaks. The internal drain tube is 5/8” standard copper tube and extends to within a 1/4” of the top of the cooler. That insures all air will be pushed out of the cooler body and eliminates the need for a separate external return tube or hose. Drilled laminated Plexiglas also serves to minimize many leak prone hose elements. All of those mating surfaces have automotive paper gaskets that swell when a liquid is present, and allows diss-assembly without scraping off a lot of dried goo.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 18th June 2013, 10:03 PM   #1982
The radiator is actually a heater core from a Ford Mustang purchased years ago from the former computer cooling enterprise – Danger Dan. They are available at most auto supply stores and of course, your local junk yard. This one was ~ $25. The fan is a Thermalright TR TY – 150. It is capable of rotating between 500 and 1100 RPM.
The water circulation system consists of a tiny DC submersible pump, again to eliminate tubes and hoses even more. In and out flow is accomplished using 3/8 copper tube. The extended return terminates at a point below the functional water level and defeats the natural tendency of water to seek it's lowest level. As long as the loop is sealed the reservoir can be located at any location.
Bob M.
Old 18th June 2013, 10:05 PM   #1983
So how efficient is it? I almost fell off my chair in disbelief at the first test Friday evening. With the F5 operating for forty minutes, ambient was 26 C, cooler was 27 C and the bolt on the power transistor was 27 C.
WOOOPPPEEE !!
Those temps stayed consistent for over an hour. A quick message to 6L6 confirmed it was actually running far below optimum temperatures for the F5. In all honesty, I had intended this radiator for a Burning Amp project in the future, but as the previous version (#4), using a double thick radiator with two 80 mm fans only produced .045 c/w (less than air systems), I went for “Mustang Sally” as Mr. X calls it.
The first test used an 8.5 VDC wall wart for the fan and a 5 VDC for the pump. No sound could be heard at 2 feet. I oriented the fan to draw air in to use the case as a noise dampener – if necessary. Using the 5 V PS for both fan and pump all but eliminates any concern for rotation and/or vibration noise. I'll include a recording in the full build post to come later on the other thread.
I started a presentation chassis a few days ago that strives to keep the entire system as compact as possible. It is a work in progress and I skipped several elements such as the thermistor system, a power switch/LEDs and both the radiator and the reservoir still need drains. It's very utilitarian now and needs a lot more wood trim to cover screws and rivets and other cosmetics. The top is actually phoney, but I'm tired.
All in all, I'm quite happy with the results. The next application appears to be the BA project packed in a 8” X 10” X 12” chassis with maybe four output boards . I'll probably bump this F5 back down to a standard 120 mm system that works well with the Honey Badger clone.
Now that's a "COOL" F5 amp,
Bob M.
Old 18th June 2013, 10:06 PM   #1984
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by bcmbob View Post
..... water has an enormous heat adsorption capacity – far beyond any metal.
water removes heat very fast
but only if you continue to remove the accumulated heat from the water
or else the cooling process ends
oh lord, I had not yet seen the last page coool
Old 18th June 2013, 10:23 PM   #1985
AudioSan is online now AudioSan  Norway
WOOOOW exelent work
Old 18th June 2013, 10:48 PM   #1986
Thanks, Lots of fun to do.
Bob M.
Old 18th June 2013, 11:00 PM   #1987
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Awesome work Bob! Congrats on a very cool amp.
Old 18th June 2013, 11:05 PM   #1988
Thanks Mr. X. You know I'll be depending on your knowledge and background for the next one.
Bob M.
Old 18th June 2013, 11:06 PM   #1989
duder1982 is offline duder1982  United States
duder1982's Avatar
Thats pretty neat. Do you ever have to replace or add water if so how often.
If I cant build it or fix it I really dont want it.
Old 18th June 2013, 11:12 PM   #1990
lanchile is offline lanchile  United States
lanchile's Avatar
You should put a few drops of BLEACH in the water to kill some bacterias or the water will start smelling bad with time.
Make it simple...Make it better!
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
