Pictures of your diy Pass amplifier
Old 15th May 2013, 08:05 PM   #1881
massimo is offline massimo  Italy
Very nice Walter. I clearly recognize your Swiss half in this building
Where did you source the heatsinks? They aren't from hifi2000....
And what about the white pcbs?
Old 15th May 2013, 08:06 PM   #1882
overtheairbroadcast is offline overtheairbroadcast  Canada
WalterW, that is one heck of a beautiful build.
Old 15th May 2013, 08:20 PM   #1883
WalterW is offline WalterW  Netherlands
Thanks everybody!
@Massimo: white boards are from forum member Teabag.
Heatsinks: https://www.distrelec.nl/elfa3~nl_nl...5-641-31&hst=4
Please don't buy them all
I used 4 of those for this build.
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced
Old 15th May 2013, 08:21 PM   #1884
biju55 is offline biju55  India
biju55's Avatar
Walter W .. Nice!!!
That is some great work!
Old 16th May 2013, 12:30 PM   #1885
Abraxas336 is offline Abraxas336  Europe
Abraxas336's Avatar
Nice built - no much unnecessary space in there . 1.25A @ 33.2V sounds pretty fearless to me . Whats the temperature of the Mosfet and whats the temperature of the diode heat sink?
Sven
Gruenschnabel
Old 16th May 2013, 01:26 PM   #1886
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by WalterW View Post
The MOSFETs are biased at 1.25 A each at 33.2 volts. Max temp on the heatsinks of 52.3 degrees Celsius.
Funny thing, your heatsink in 200mm height, would go up ~34C for 166W dissipation. (according to the datasheet)
At 25C ambient, close to 6OC heatsink temperature.
And only provided that the C/W number need not be corrected for operating at dT above ambient.
Your numbers suggest that the overlapping way you attached the square framework bars to the heatsinks, draws some serious heat away from the primary coolers. (aka rather interesting)
Definitely the looks of a couple of hundred hours of sweating.
Only pancakes for you, the schmokes are already there.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 16th May 2013, 05:10 PM   #1887
Hi Jacco,
Your calculation is right, you just assumed my Tamb is 25C, but hey at this moment it is 18.7C in my shack.
Thanks to the fact we haven't seen the sun here in Utrecht since the beginning of 2013 The worst spring ever....
Even in my livingroom it's barely 20C.
But I must say the heatsinks really starts to dissipate above 50C, even when pulling 400 watt from the mains, they were still below 60C, don't know the exact numbers, I was too busy shutting the amp down
Old 16th May 2013, 10:58 PM   #1888
Brrrr, your Swiss side, I suppose ?
(really good heatsinks, though. ~1 dm3/W/C )
Old 17th May 2013, 08:04 AM   #1889
Sven
I've been measuring this and it concerns me... when the amp is around 53C the outputs are around 70C, I even measured 71,2C as max
On average I would say the housings of the MOSFET are around 15 degrees hotter than the heatsink... seems a lot...maybe my mica / silicone paste combi isn't that good.
Though I already splitted the mica insulators twice. So four times thinner than original.
The diodes under the transformers are around 45C, so that's OK.
Old 17th May 2013, 09:09 AM   #1890
derwhalfisch is offline derwhalfisch  New Zealand
WalterW - buy Keratherm pads from Zhoufang in vendor's bazaar... 0.07 degC/W
All IME, IMO and IMU of course
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 11:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 07:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 01:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 3rd March 2004 12:00 AM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 08:27 PM
Copyright ©1999-2017 diyAudio
