Pictures of your diy Pass amplifier
Old 8th May 2013, 02:20 AM   #1861
CanAm Man is offline CanAm Man  United States
Eric...great looking amp--and a great way to introduce your daughter to the hobby....!!
Old 8th May 2013, 11:32 AM   #1862
Eric is offline Eric  United States
Eric's Avatar
Very nice, Ken! I didn't realize what type of wood you had used when I first saw your amp. Do the wood panels have any negative impact on the air flow through the sinks? This is an interesting approach to dress up the amp! I've also enjoyed the handful of amps that people have shown with sinks mounted on the inside of the chassis. Both are a little different than the norm.
Eric
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 13th May 2013, 04:00 PM   #1863
Eric--No. In fact, the wood panels are an integral part of my heatsink cooling system. I have two muffin fans on the rear panel of the amp, that flow air into the central part of the chassis. From there, the air flows under the heatsinks (machined, for that purpose), and then the air flows upwards between the heatsink fins and wood panels. The air exits at the top. As such, I have both forced air (fans) and thermal convection (from the effect of a "thermal chimney" of the fins and wood panels). Works great.
I suspect the amp would run a lot warmer without the wood panels--would ruin the desired air flow path thru the amp.
Old 13th May 2013, 04:06 PM   #1864
6L6 is offline 6L6  United States
6L6's Avatar
CanAm Man's amp probably has enough excess cooling he could run a hot F5T in it with little worry - I have had the honor of seeing it in person, it's one of those DIY projects that makes you want to aspir to that level of quality and detail.
Also, the panel meters are amongst the coolest things ever.
Old 14th May 2013, 07:11 PM   #1865
WalterW is offline WalterW  Netherlands
Finally ready!
Here are the latest pictures of my completed F5Turbo v2 with cascoding, with 2sj201/2sk1530 output MOSFETs and the diodes MUR3020W mounted on the heatsinks. I'm not a ''fraidy-cat" but hey, my sourceresistors are only 0.22 Ohm...
The frontpanel is wonderful made by Andrea of hifi2000.
The MOSFETs are biased at 1.25 A each at 33.2 volts so 40 Watts each.
Total power consumption is around 350 Watt, with max temp on the heatsinks of 52.3 degrees Celsius.
I first biased it around 380 Watt put the lid on the amp and I almost had a thermal meltdown
Took me hundreds of hours to complete....
Hope you like the pictures...
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 14th May 2013, 07:14 PM   #1866
and some more....
Old 14th May 2013, 07:18 PM   #1867
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Wow, very nice.
Old 14th May 2013, 07:23 PM   #1868
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Fugly!
put 5mm spacers between heatsinks and both bottom and top plate , to have opening all around circumference ; that way it will have more air for inside cooling
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 14th May 2013, 07:24 PM   #1869
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
help..I can't breathe..it's hot...and tight...man, that thing will be boiling hot like a vulcano
Old 14th May 2013, 07:27 PM   #1870
Thanks!
Ofcourse thanks to Papa Pass for this wonderful design and sharing it with the DIYaudio community!
The first music I listened to was a SACD from the Dire Straits, Brothers in Arms...your latest trick...WOW
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
