Pictures of your diy Pass amplifier
Old 2nd April 2013, 12:31 PM   #1811
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by john65b View Post
Air conditioner condenser fans are mounted on top, sucking air through the coils
Think moisture.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 2nd April 2013, 12:42 PM   #1812
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
depends on what you want
1. blowing cool air directly on a small surface
2.removing hot air from a space
Old 2nd April 2013, 01:08 PM   #1813
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by regiregi22 View Post
Has anyone noticed that fans (at least, all the ones I've seen until now) blow air in the direction of the sticker/frame? So, as seen in the pictures, that fan is blowing air into the case from the top cover.
Have you checked that?
Just out of curiosity, then why almost all elec. equip. use to mount fans sucking air out of the enclosure?
We had a whole discussion of this a few posts back. The reason why fans pull air out is that it is generally more efficient for the entire enclosure whereas blowing in cools parts directly in flow path of fan. Has advantage of not sucking dust into box by maintaining positive pressure if used with filter over fan inlet.
Old 2nd April 2013, 09:48 PM   #1814
hippie is offline hippie  United States
Its not a amp but one of pass's other cool designs scaled down.....
Thanks for the rockin design, just wish I could build it full size, but the space isn't their....
Old 2nd April 2013, 11:24 PM   #1815
AudioSan is offline AudioSan  Norway
wery cool and a little more convenient for normal households the original damands a lot of Space
Old 4th April 2013, 10:34 PM   #1816
Blink_PT is offline Blink_PT  Portugal
Blink_PT's Avatar
Of the many experiences I had with fans, this is the one that gives better results.
A rear blower 80 to draw air, and two fans 92 to provide air channels to the pcbs.
Fans DBs are low, 10 and 17dBs.
One thing I discovered, if you connect a sensor F5T temps and only when it is hot it turns the fans, takes a long time to cool down.
I removed the sensor, when I turn the F5T the fans start to spin, then the temps will keep a long time with very reasonable temperatures.
Old 5th April 2013, 07:44 AM   #1817
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
I think general situation in our conventional class A amp designs is option 2, right? We use to spread trannies along big heatsinks with a big area. Heat is more or less the same along the whole internal enclosure area (after a considerable amount of time needed to stabilize temps, lets say, one hour?). My point is that there are no real hotspots, my class A amps are hot anywhere, including front handles if they're installed!
I have measured with my IR thermometer that difference betweent the hottest and the coldest spot along the whole amplifier is no more than 10º.
Using an small heatsink installed inside the enclosure for the purpose of being active refrigerated is a whole different point, so option 1 would apply.
Sorry guys, xrk971, for being late to the discussion, I didn't see there were two more pages of discussion messy head I have....
Oh, and as a side effect, if you put a filter in a fan blowing air out, you have a permanent steady vacuum cleaner that may aid to keep your room cleaner
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 6th April 2013, 03:14 AM   #1818
duder1982 is offline duder1982  United States
duder1982's Avatar
What is that it looks really cool, how big is the original. I take it that is a full range driver. How does it sound.
If I cant build it or fix it I really dont want it.
Old 6th April 2013, 03:25 AM   #1819
Got Foam?
xrk971's Avatar
Did you make this out of foam core? Very cool, I have been thinking of doing a very similar design. If it is foam core did you know that you can produce beautiful smooth bends with it by scoring the concave side to pierce the paper?
See this thread Foam Core Board Speaker Enclosures?
Old 6th April 2013, 03:47 AM   #1820
Thanks man, here's the real one, It's huge!
http://www.mh-audio.nl/Downloads/KleinHorn.pdf
the whole thing is foam board, I wanted to test it before i build one out of wood, because i had no idea how it would sound scaled down. for the bends i did score it, but i put the score mark's on the outside so that the inside was completely smooth.
The drivers were given to me by a friend and have no marks but they rock, since this pic I've added a phase plug and have been messing with a wizzer cone, not successfully yet though.
The sound, is just great, they do nothing offensive, they can't go supper low, nor really high, but the mid range is magical. I'm just curious what the real one sound like compared to my cheap copy. There also just great for movies if you add a sub. Just so spaceish sounding its crazy.
Unfortunately they're just so ugly that they're going back in the basement...
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
