Pictures of your diy Pass amplifier
Old 8th March 2013, 06:12 PM   #1711
NSP is offline NSP  Finland
Someone made me drink too much beer tonight. 18+18 volts is what I ment. As we say in Finland "Kippis"
Old 8th March 2013, 06:12 PM   #1712
WalterW is offline WalterW  Netherlands
Looks great, that's gonna be a fine case when finished. How on earth do you make you're own transformer casing?
BTW: the transformer looks a bit small for 2 x 18V, 600VA, or is it just the picture?
Old 8th March 2013, 06:30 PM   #1713
Thanks Walter!
The transformer is about 150 mm in diameter, 40 mm high and weighs about 5 kilos. I ordered it from Toroidy so I hope it's the real deal.
The transformer casing is made out of 3 mm thick sheet metal that i rolled and TIG- welded together. Then a 3 mm lid was silver soldered on and trimmed down to right diameter in a lathe. Quite easy made, but I hope the inside of the amp will be more "clean" looking.
Here are some pics of the casing.
Old 8th March 2013, 06:45 PM   #1714
massimo is offline massimo  Italy
Originally Posted by NSP View Post
Quite easy made....
Maybe for you, not for us without the right tools...
Nice work nonetheless
Old 8th March 2013, 07:00 PM   #1715
Thing is that I don't own any tools that can do that, I just happen to work at a place that got the right tools and machinery that I sometimes use for my own hobbies.
Thank you!
Old 8th March 2013, 07:07 PM   #1716
If it weighs 5 kg it's 600 VA !
Old 8th March 2013, 09:53 PM   #1717
I thought so. It's big and heavy!
Old 8th March 2013, 10:04 PM   #1718
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I just hope you're not going to drill a hole in center of it ........ and to put common screw , for both toroid and cover
( we already had few examples , needing 3 pages of explanation to builder , that he is having short circ messing with precious toroid , while he wasn't prepared to believe that we aren't pulling his leg ; one of most interesting cases was with guy - having two toroids , with short circ common for both of them , and - luckily - just fact that they were antiphase connected on common mains cable , saved it from fire or something like that )
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 8th March 2013, 10:10 PM   #1719
Zen Mod- Put a common screw through the transformer and casing is exactly what I'm going to do because the transformer that I ordered has a epoxy filled center and no metal in sight.
Old 9th March 2013, 12:27 AM   #1720
coils is offline coils  United States
Use a nylon screw, prevent the shorted turn.
Coiler
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
