Pictures of your diy Pass amplifier
Old 27th February 2013, 07:39 AM   #1661
Kjeldsen is offline Kjeldsen  Denmark
Agree on Nexus fans. I have them in my HTPC, and they are really silent. No need for fanless PC's with good silent fans.
Old 27th February 2013, 09:39 AM   #1662
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Sure, just fit the biggest heatsink you can find, a pair of 12cm fans running at 20-30% their rated speed isolated from chassis with rubber gomets, isolate mechanicals hard drives from the case, and you won't hear it. Sorry for the OT.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 27th February 2013, 09:50 AM   #1663
bcmbob is offline bcmbob  United States
reg, not sure that's OT because those are the techniques that are necessary if one adopts liquid cooling for power amps. The physical isolation is key for use with audio. What are you using to regulate the fan speed?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 27th February 2013, 10:20 AM   #1664
JohnGeneva is offline JohnGeneva  Switzerland
Walter, nice build. What is the purpose of the caps which are mounted on the diyaudio f5 board. Is there are reason they are put there and where do you install them, (before the _+ - voltage in? Does this help the sound quality? I am wondering if I should put some on mine also. thanks, John
Old 27th February 2013, 11:15 AM   #1665
regiregi22's Avatar
One of these controllers, they are just potentiometers acting as a voltage divider (no active devices involved) AFAIR. I got it for something like 10€ and fits in a 3.5" bay. Nice blue leds and overall finish. I currently have it disassembled due to a new computer I am building, so would you like me to draw down the schematic, resistor values and so?
http://i01.i.aliimg.com/wsphoto/v0/6...Controller.jpg
It is VERY important to fit the fans with those grommets, so vibrations will not be transferred to the enclosure. Even at 100% full speed, if properly isolated, a Nexus fan will be pretty much silent inside a case.
http://reviewstash.com/files/NF-P14FLX/fanmount.jpg
Old 2nd March 2013, 09:04 AM   #1666
carsten.witt is offline carsten.witt  Germany
carsten.witt's Avatar
Hi together,
finished my Pass Aleph mini .... little 14 kg weight!
Click the image to open in full size.Click the image to open in full size.
Regards ............Carsten
Old 2nd March 2013, 10:22 AM   #1667
WalterW is offline WalterW  Netherlands
Hi John,
I got a hint from an other DIY that putting a little 'audio grade' capacitor will give it a better sound, details in the highs and so... because my large Panasonic capacitorbank is computergrade...
I don't know if it really matters, I can't hear the difference.
But it is common here, to put a large polypropyleen capacitor ( 4u7 - 10 uF) over a big capacitorbank.
You can put some on the F5 board, but you've got to improvise with big wires underneath the board.
Walter
Old 2nd March 2013, 10:25 AM   #1668
Wow, looking great Carsten! Mini ?.....
Are the toppanels from Frontpanelexpress?
Old 2nd March 2013, 10:41 AM   #1669
@WalterW,
Thanks! ...."J"
No, they are from Schaeffer AG in Berlin.
Old 2nd March 2013, 10:56 AM   #1670
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by carsten.witt View Post
mini
You sure that's Left and Right ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
