Pictures of your diy Pass amplifier
Old 15th February 2013, 11:09 AM   #1601
sakellogg is offline sakellogg  United States
sakellogg's Avatar
Hacksaw and files! Wow that's diy!
Looks very nice. I like.
I'm not crazy, my mother had me tested
Old 15th February 2013, 01:20 PM   #1602
WalterW is offline WalterW  Netherlands
Very nice Omishra !
Nice layout. Good idea to put the tranformer under the capacitors.
I'm building a similar Turbo version 2, and keep that in mind...
Is the 0.55A bias the maximum the heatsinks can disipate? How hot do they get? Cause if I calculate 2.2A x 33V it is "only" 73Watts per sink, and it looks like they can do much more...
From where did you get the speaker ground to the connectors? From the amp-pcb or from the PSU?
Old 15th February 2013, 01:21 PM   #1603
john65b is offline john65b  United States
john65b's Avatar
Are the transistors connected to the sink with an L bracket?
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 15th February 2013, 02:41 PM   #1604
omishra is offline omishra  India
Thank you everybody!
No, they are directly over the heatsink. Please see more pics here.
Old 15th February 2013, 02:58 PM   #1605
bcmbob is offline bcmbob  United States
What did you use for insulators on the HS/transistors joint? They are very clean and appear as no spacer was installed. I've been looking at this.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 15th February 2013, 04:01 PM   #1606
boywonder is offline boywonder  United States
boywonder's Avatar
FWIW, I have a roll of Kapton/polyimide tape left over from another project that I have used on my DCB1 buffer and Mini-A without issue (so far). I applied the tape to the part, used a small drill bit in my fingers to poke the hole for the screw, and trimmed the edges with a razor. I did not use any grease although perhaps I should consider that......
Old 15th February 2013, 04:09 PM   #1607
Thanks for the info. My thought was using the film would eliminate any heat insulating properties of the tape. Should have some on hand (1" wide) next week and will experiment.
Bob M.
Old 15th February 2013, 04:31 PM   #1608
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
http://www.linearaudio.net/images/st...%20PK%20lr.pdf
http://www2.dupont.com/Kapton/en_US/..._datasheet.pdf
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 15th February 2013, 04:54 PM   #1609
jacco, that's a great link and exactly what I've been looking for over the past few days. I was on that Dupont site but couldn't find a retail vendor. Do you know of a source?
Bob M.
Old 15th February 2013, 04:59 PM   #1610
Fraid not, Kapton isn't my thing, sorry.
(just thought you might like to see the numbers)
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
