Pictures of your diy Pass amplifier
Old 12th July 2010, 08:38 PM   #121
Tripmaster is offline Tripmaster  United Kingdom
Tripmaster's Avatar
Originally Posted by jleaman View Post
Looks good, personally id upgrade those output wires to a bit thicker Thats kinda small wire..
Hi
Its just a twisted pair cat5 cable. What would you suggest? The reason why I choose this, apart from having a pile of it, was that Dave (Planet10) suggests using a single pair for the speakers cables.
Old 12th July 2010, 08:47 PM   #122
Jacques Merde is offline Jacques Merde  United States
Jacques Merde's Avatar
Very nice, Richard. I like the cleanness of it. Looks like everything bolts directly to the heatsinks. have you any shots with the cover off?
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 12th July 2010, 08:49 PM   #123
Tripmaster's Avatar
Check the third pic
Old 12th July 2010, 08:49 PM   #124
Never mind Odd, the cover-off shot didn't render on the first view. Oh well.
Old 12th July 2010, 09:11 PM   #125
HaflerFreak is offline HaflerFreak  United States
HaflerFreak's Avatar
That is one beautiful amp, congratulations.
I found your amp very interesting because I was planning my build to be very similar, although with Peter Daniels boards.
I must say, I would not normally speak up, but I must agree with jleaman - that cat5 output wire has gots to go!
As for a suggestion, I would say 18 or 16-guage. I am going to be using regular old stranded copper 16g.
Once again, hurrah on another F5 added to the world, I sure wish I could get mine done!
Old 12th July 2010, 09:49 PM   #126
Melon Head is offline Melon Head  Australia
Banned
Originally Posted by Tripmaster View Post
Hi
You really need to use speaker cable for the output, or at least something much thicker. I don't think cat5 will handle any significant current (2A at a guess).
You are also increasing the output impedance of the amp.
If the insulation melts, then you are going to short the amp (because of the twisted pair).
Old 12th July 2010, 09:59 PM   #127
Tripmaster's Avatar
I'll get to it right away! Thanks for the advice guys.
Old 12th July 2010, 10:03 PM   #128
Puffin is offline Puffin  United Kingdom
I'm sure you can surpass my efforts
Oooh No, Yo da man!
Old 12th July 2010, 10:32 PM   #129
Tripmaster's Avatar
Hi
I have some DHLABS silver plated hook-up wire. It has a diameter of around 1.5mm
wire_hookup_dhlabs
Will this be OK?
Old 12th July 2010, 11:02 PM   #130
lgreen is offline lgreen  United States
lgreen's Avatar
I just did a quick google search; 1.5 mm is about .05 inches which is about 16 gauge which is about about 13 amps. Should be plenty.
There are a lot of web sites out there that give wire diameter and current limits. Here is one: Xtronics Wiki.
Retired from DIY (2010) but still lurking now and again. My DIY audio projects- PartTimeProjects.com.
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 11:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 07:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 01:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 3rd March 2004 12:00 AM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 08:27 PM
