Pictures of your diy Pass amplifier Pictures of your diy Pass amplifier - Page 124 - diyAudio
Old 19th May 2012, 06:30 PM   #1231
AudioSan is offline AudioSan  Norway
maybe you can get 1cm cut off of th sinks? thats the easy way
does the noise change with volume? and have you tryed with differnt sources?
Old 19th May 2012, 06:31 PM   #1232
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by wengtech View Post
too bad, the height of chassis is not fit for 15cm, only 14cm.
that is why i lay them down, but it true the heat was trapped inside.
so i need a modification here.
do you have enough deepness for 3 of them , as I said previously , rotated for 90 ?
yes, both.
sound like "bees" when the volume set to half, no music.
very little, but however i must eliminate them.
what sort of volume , with or without the source ?
do you have a scope ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 19th May 2012, 06:42 PM   #1233
ZM. are yo thinking of making the sinks as a tunnel and use a slow fan?
Old 19th May 2012, 06:47 PM   #1234
Zen Mod's Avatar
exactly , same as was the case with amp originally in that case/box
there is no other way .........
Old 19th May 2012, 06:54 PM   #1235
ZM. i have some doubt that the chassis is 450+mm deep. but is sure is 300+mm deep
that will work if the boards is not way over 300mm wide
Old 20th May 2012, 02:38 AM   #1236
wengtech is offline wengtech
noise doesn't change with the volume.
3sink rotated need 45cm and my chassis only 40cm.
the bees occur with the source, when i disconnect the source it is gone.
i use old pioneer cdplayer.
yes you are right not enough deep.
Old 20th May 2012, 04:45 AM   #1237
gen48 is offline gen48  South Korea
Wink My UGS Preamp
I made this for three years.
2sk389BL,2sj109BL,ztx450,ztx550,remote contol,acryl-sash
Old 20th May 2012, 05:02 AM   #1238
Jay is offline Jay  Indonesia
Banned
Sounds like transformer buzz. Good grounding will help (ground the "body"/leg of the EI trafo properly) but when the trafo must operate very hard (close to its full capacity) there is nothing you can do to make it buzz-free.
Such looking trafo are common in my area too. They are written with "A" (ampere) capacity. But they performance is much lower than that, and is easily buzzing with class-A constant current draw. But if you're trafo is not hot then it is okay I guess.
Old 20th May 2012, 05:20 AM   #1239
Banned
A slight improvement without having to cut anything is by turning the heatsink up side down (the pcb will be underneath). This way you give more room at the bottom and also less heat trapped.
The heatsink and the mosfet is capable of handling the heat, but using such L-shaped aluminum you have to make sure that the heat will quickly transferred from the mosfet --> L-profile --> heatsink --> air.
I have never used L-profile for class-A amp! If I have to I will use double L-profiles. Connections between heatsinks must be tight using compound after sanding the heatsink on level surface (I use glass surface). One of my amp is using similar intermediate profile but made of copper, not Al.
Old 20th May 2012, 11:22 AM   #1240
it seams your bees is are a product of a groundloop in the signalway
do you have another source to try?
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
