Pictures of your diy Pass amplifier
Old 6th April 2012, 10:39 AM   #1171
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Originally Posted by artmachine View Post
the pcb and components usedClick the image to open in full size.
Uploaded with ImageShack.us
Replace those awful Tantalums next to the input MOS-FETs and you will hear a MASSIVE improvement. We used ELNA Silmic II. The Tantalums gave the amp an awful sibilance.
Old 6th April 2012, 11:32 AM   #1172
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by buzzforb View Post
Who is this John.
MJL21193, John's a pro carpenter something.
1000 Watt Sub Amp: Design / Build
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 6th April 2012, 12:16 PM   #1173
If you read through my Brother-in-Laws original thread you can see some of the lessons that he learned.
Aleph 4 Strickly DIY Project Build
I can see remarkable similarities in the two projects.
Old 7th April 2012, 03:10 PM   #1174
artmachine is offline artmachine  Italy
artmachine's Avatar
I will try your solution
But because Mr. Pass uses tantalum in the aleph series?
my amp sounds great so it does not have any problem.
Old 7th April 2012, 03:27 PM   #1175
luvdunhill is offline luvdunhill  United States
luvdunhill's Avatar
I have found that wood can act as a resonator and amplify any mechanical noise emitted from a transformer. That being said, it doesn't stop me.
For Sale: Yet-Another-FirstWatt-PSU | "CSX1/2" "Buffered F6" FE
Old 8th April 2012, 06:43 AM   #1176
ewhitaker is offline ewhitaker  United States
Didn't build it. Had Tim Rawson make it. The original transformer by Krell failed and was irreplaceable. It's an Aleph 2 clone with all Pass Labs boards. I fashioned the bus plate from 1/4 inch copper just because it looked cool. The fins are almost adequate. In warmer months it can start getting too hot, so it's my winter amp.
Old 8th April 2012, 11:22 AM   #1177
Mr Rawson must be a pretty smart guy.
Personally, i don't quite see how to get 2 times 300W dissipation from a KSA150 chassis, that was designed to handle 300W total at idle, aka 75W per heatsink.
(e.g., the official Krell brochure of the MDA300 model states 400W dissipation from 6 of the exact same heatsinks, same chassis as the KSA250, aka 67W per heatsink)
At least the front end boards have Mr Rawson written all over them.
Old 8th April 2012, 11:52 AM   #1178
Mine might have had rubbish tants in it but the ELNA Silmic IIs made a HUGE HUGE difference.
I don't know about suppliers in Italy but here is a supplier in the UK. http://www.hificollective.co.uk/comp...apacitors.html
If you cant get them let me know, they should post out to Italy though.
Old 12th April 2012, 04:23 AM   #1179
oneplustwo is offline oneplustwo  United States
oneplustwo's Avatar
Evanc - Sorry for missing this earlier. Thanks for following the thread. I had fun building it. Especially given all of the casework was scraps or repurposed parts (except for the heat sinks of course.) Even the amp board kit from techdiy was at a discount since he was nice enough to refund my money since the kits were not correct. This is probably the cheapest F5 ever built!
The F5 is so simple, especially compared to the Beta24 I'm currently trouble shooting. And of course, it sounds great.
Relative to using wood in amps, I've had good luck with them in the past and now with my F5. This is probably my 5th project with wood pieces integrated to some degree. Also, I personally like the contrast in material choices.
Originally Posted by evanc View Post
Oneplustwo,
I followed your build thread. Glad you got it working.... Looks super. You must be proud of the result after the work you put in
Wood cases seem fine for amps, but maybe not projects that need the shielding of a metal chassis.
Evan
Old 13th April 2012, 04:35 PM   #1180
Eric is offline Eric  United States
Eric's Avatar
Default Wooden chassis
Here is my wooden chassis a40. Its been up and running for about 10 years and for the past 3 years it has been running 7 hours per day, 5 days per week with no trouble. I made it from a cut-down bed rail that I purchased for $3...
More pictures/details available in signature links.
My DIY Basement Theater, Aleph-X Amplifers and Avro Open Baffle Speaker construction pages.
Pictures of your diy Pass amplifierHide this!Advertise here!
DIY Low Pass and Mid/High Pass (Bass Blocking) Filters runslikealpaca Everything Else 1 19th June 2009 10:59 PM
Naked pictures of Pass Pete Fleming Pass Labs 30 9th December 2006 06:39 AM
My new hifi amplifier (pictures) Wejp Chip Amps 23 15th October 2004 12:16 AM
Pass Diy High Low Pass Please macka Pass Labs 127 2nd March 2004 11:00 PM
DIY Pass labs 100watt amplifier. microwalsh8504 Pass Labs 12 6th February 2004 07:27 PM
Copyright ©1999-2017 diyAudio
