Thanks! I'm still stuck on what to do with that giant blank faceplate. I've been looking at temperature meters but I have no idea what to look for configuration-wise if I want to do an analog meter.
Hi, what is the size of the heatsink you are currently using in your chassis for AJ ?
I am using the diyAudio 4U chassis which are 300mmx160mm40mm heatsinks.
Here's hoping that I've got everything right - one half of it is ready for testing.
I suggest using ~1/4 inch spacers to put some space between the heat sink and the steel chassis side, so that the flat part of the heat sink can cool and not be insulated by the steel.
What are the dimensions of that heatsink?
Better propective
This photo might better show the relative size of the heatsinks.
The case is a 4U chassis, the toroid is a 500VA unit.
The two big caps are 22000uF Audio Grade caps then feeding a CRC filter with 10 x 4700uF caps.
This amp is only intended to operate as the HF amplifier in a tri-amp setup.
how many fins...
Here is a shot of my newly constructed Aleph J.
The heatsinks are pretty small; each side assembly adds to about 8x10 inches of fins. The heavy aluminium brackets probably help...
I played it recently for 4 hours driving 4 Ohm speakers (KEF 104/2) straight out of the CD player and though it got hot it never got past the 5 second touch rule.
Perhaps I am just lucky so far but I might have done right by keeping the fins up high for good air flow; it was my whole intention with the tiered nature of this scrapyard build.
I'd say be smart and fearless. If it gets too hot you'll have to rebuild. Just don't leave the room while you do your testing
I love it!!
Congratulations on a successful build!
The blue glow reminds me of Cherenkov Radiation - Cherenkov radiation - Wikipedia, the free encyclopedia
I've done some assembling and wiring after I got my chassis parts home from powder coating. By the way sorry for the crappy picture quality.
Cutting some Keratherm
Inside
Grinded frontplate
Inside
Grinded frontplate
... been getting comments that my heatsinks are too small ...
may be 'smallish', but might work
could depend on your actual measured supply voltage
room temperature matters too
and maybe just don't go crazy on high bias
Looks lovely but I've been getting comments that my heatsinks are too small and they dwarf yours.
Your sinks are 56Kmm^2 mine are around 51. I may have more mass if you include the brackets the sinks mount to. Total mass is about 5.3Kg / side.
What this says to me is you should be alright on an Aleph J if you get good air flow - at least that is my experience
The end result looks very nice, like the blue light coming from it...
Enjoy listening to it !
Walter
Inside ...
That looks awesome !! Extremly clean build !!
- Pictures of your diy Pass amplifier
