Zen vs. GainKlone
Zen vs. GainKlone
Old 19th June 2003, 06:10 AM   #21
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Originally posted by Peter Daniel
I built chassis for SOZ a year ago. It will be 10W version. It's only that I got involved with all that GC craze, that I didn't have time to pursue other designs. But I learned a lot playing with GC and I will be using probably different components, that I initially planned with SOZ. 500VA toroids are at the bottom. I also bought 15ohm, 30W Caddocks, I'll be using in parallel.
If you are willing to tweak your SOZ as you have done with your GC's, you're in for a BIG surprise as the differences are much bigger between components. As to the MP930; very dry and clear/detailed, but a little too much in my setup with the SOZ..
It is a little more work to change resistors etc though...
Mads K
Old 19th June 2003, 01:37 PM   #22
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Zen vs. GainKlone Send a message via AIM to Peter Daniel
Any better alternative?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 19th June 2003, 03:13 PM   #23
Mad_K's Avatar
The Dale's Nelson mentiones in the article sounds more natural...
Mads K
Old 19th June 2003, 03:16 PM   #24
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
i guess if resistors make a difference in sound,
this is the circuit that would bare it out
but i think like Peter is hinting at, there aren't that
many high power resistors to choose from.
i used the Dale resistors rated at 50 watts, even for
the 1 ohm resistors. I think i liked the idea that they
were all the same.
Old 19th June 2003, 03:21 PM   #25
I've got Dales too.
www.audiosector.com
Old 19th June 2003, 06:58 PM   #26
moe29's Avatar
i'm looking forward to that:
This is not just another SOZ post
GainKlone's and Zen amps are pretty much apples and oranges
though. When you see the word Compare, the first thing you
think is that one will be determined to sound BETTER than the
other. I guess i'm just more interested in seeing if they have
similar traits/strong points. The two amps truly are the kings of
minimalism. That's what attracts me to the SOZ.
Old 19th June 2003, 07:52 PM   #27
Mad_K's Avatar
I've got Dales too.
Then you can try both!
I am interesred in trying the Danotherm GRF 20/102 (6.8 ohm/80W)
http://www.danotherm.com/engelsk/pro...tors/round.htm
Then I wouldn't need heatsinks
Mads K
Zen vs. GainKloneHide this!Advertise here!
My new wooden gainklone DT Chip Amps 8 6th August 2005 02:09 AM
Another GainKlone is alive and singing! overmind Chip Amps 12 25th May 2003 03:49 AM
Newbie GainKlone VoLCoM Chip Amps 12 18th April 2003 04:10 AM
gainklone problems, maybe... cowanrg Chip Amps 44 25th February 2003 05:16 PM
