Zen vs. GainKlone
Zen vs. GainKlone
Old 18th June 2003, 04:39 PM   #11
garnex is offline garnex
hi,
what type of cardas wire do use, peter?
regards,
garnex
Old 18th June 2003, 05:02 PM   #12
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Zen vs. GainKlone Send a message via AIM to Peter Daniel
It is chassis hook up wire, 19 or 20ga.. It is kind of harder to terminate as the strands are enamelled. But it sounds mor 3 dimentional than Kimber I was using previously.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 18th June 2003, 05:30 PM   #13
Tazzy is offline Tazzy
Send a message via MSN to Tazzy
Peter, could you tell me what type of cardas wire you used?
As I'm trying to buy some for my amp projects
Old 18th June 2003, 05:47 PM   #14
Go here: http://www.percyaudio.com/Catalog.pdf On page 2 you'll see Cardas chassis wire, 20.5ga.
www.audiosector.com
Old 18th June 2003, 05:49 PM   #15
Thanks!
Old 18th June 2003, 05:55 PM   #16
I believe Partsconnexion.com also carry that wire.
www.audiosector.com
Old 18th June 2003, 05:57 PM   #17
I looked it up in a Gauge to Metric table... Do I got it right that this wire is 0,5mm thick?
Old 18th June 2003, 06:07 PM   #18
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Peter, Go for the SOZ, i'd love to see what you come up with!
(they do run HOT though, even at 10 watts!)
((i thought your AX was pretty "no holds barred" already
my brother asked me what i thought the difference was between
my SOZ and Aleph 3 (commercial)... it's hard for me to say.
I guess i'm just bad at comparing things. I think i like the Aleph 3
more, but i think it's just 'cause i'm used to it, and the SOZ hasn't
burned in yet (not even in final case yet)...
comparisons... tricky.
build and have fun!
m.
Old 18th June 2003, 06:28 PM   #19
I think it's pretty close to that in diameter.
www.audiosector.com
Old 18th June 2003, 06:35 PM   #20
I built chassis for SOZ a year ago. It will be 10W version. It's only that I got involved with all that GC craze, that I didn't have time to pursue other designs. But I learned a lot playing with GC and I will be using probably different components, that I initially planned with SOZ. 500VA toroids are at the bottom. I also bought 15ohm, 30W Caddocks, I'll be using in parallel.
www.audiosector.com
Zen vs. GainKloneHide this!Advertise here!
My new wooden gainklone DT Chip Amps 8 6th August 2005 02:09 AM
Another GainKlone is alive and singing! overmind Chip Amps 12 25th May 2003 03:49 AM
Newbie GainKlone VoLCoM Chip Amps 12 18th April 2003 04:10 AM
gainklone problems, maybe... cowanrg Chip Amps 44 25th February 2003 05:16 PM
