Old 5th May 2010, 02:16 AM   #1
Default RIAA caps for Pearl and Pearl 2
Hi All,
Just starting to throw together a Pearl and found that some of the RIAA filter caps are obsolete as of 2008 (at least according to digikey).
That is, the Panasonic P series
P3473-ND 0.047uF, 50v
P3334-ND 0.33uF, 50V
Although digi still has the P3124-ND 0.12uF, 50v
I checked out Mouser and a few others but can't find any.
Anyone know where to get them or suitable replacements?
Thanks,
Jeff
PS I'm assuming the Pearl 2 has the same RIAA section but a new source for the caps
Old 11th May 2010, 01:26 AM   #2
Borbelyaudio has some of the ECQ-P 0.33uF/50V but at 3 euro each!
The Digikey catalog page lists some cross references:
Sprague: 715P
Westlake: 173/174
Mepco: 719E1/719H1
Secor: PFDS/PFDR
Roderstein: KP1835
Wima: FKP CSF
Thompson: PL/PS
Rubycon: PP
Nisseip: APS/APA
Mouser carries the Sprague 715P at .33uF/200V but these are the orange drop ones and I was under the impression they aren't meant for filters.
Any other hints or suggestions?
Surely, I'm not the only one who's run into this? ... I know, I know ... stop calling me Shirley ...
Jeff
Old 11th May 2010, 07:34 AM   #3
massimo is offline massimo  Italy
Digikey has the Vishay MKP416 pp caps and Mouser the Wima FKP2 pp caps, both better than Panas IMHO.
Old 12th May 2010, 12:00 AM   #4
AVWERK is offline AVWERK  United States
715p are steel leads (ugh)
716p are copper leads
David
Old 12th May 2010, 01:30 AM   #5
Hi Massimo, thanks for the help.
The Vishay MKP416 are metallized polypro whereas the Pan ECQP and Wima FPK2 are not.
Mouser's Wima FPK2 only go up to 0.033uF and I need 0.33uF.
Jeff
Old 12th May 2010, 08:12 AM   #6
An Aussie member reported the MKP416 as a very good sounding cap.
Yes, Wimas are film and foil, but you can mix them (i.e. C17 = 333nF = 100nF x 3 MKP416//33nF FKP2)
Pearl Two wayne Pass Labs 1512 24th May 2012 02:24 PM
pearl HELP! d to the g Pass Labs 24 31st May 2007 01:56 PM
Question about the pearl RIAA stage lordvader Pass Labs 25 20th December 2006 12:02 AM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
Pearl - bypass caps yes or no? Boban Pass Labs 9 29th September 2003 01:30 AM
Page generated in 0.08168 seconds (73.30% PHP - 26.70% MySQL) with 10 queries
