Pass Labs B4 crossover questions
Old 21st April 2018, 11:18 PM   #311
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally Posted by MEPER View Post
dB is 20 * log(Vout/Vin)
Is there a scaling factor missing? Normakized to the 1st measurement at 10Hz.
Pass Labs B4 crossover questions-tannoyhpd385-db-chart-png
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd April 2018, 02:42 AM   #312
woofertester is offline woofertester  United States
Originally Posted by nzlowie View Post
Here is the result, bigish dip in the 3500 to 500hz area.
This measurement was inside so bass is a bit over the place.
The ripple of the low frequency driver seems notable. It reminds me of the ripple that occurs with an unstuffed transmission line for the octaves immediately above the 1/4 wave length tuning frequency. I have never seen a room do this to a speaker. I have seen this when you attach a driver to a long PVC pipe.
Old 22nd April 2018, 03:53 AM   #313
nzlowie is offline nzlowie  Australia
Yea the bass is a bit wobbly but those are room nodes as the measurements were taken inside. The dip that concerns me is the top of the mid drivers range which when summed makes the dip from 3500 to 5000hz. (Not 3500-500 as first mentioned.)
Trouble the natural roll off of these drivers is virtually identical to the cross over, the crossover really only appears to provide protection.
Old 22nd April 2018, 08:05 AM   #314
MEPER is offline MEPER  Denmark
dave
As far as I know dB is just a way (logarithmically) to show the relation between an input and an output. Then it has been defined the way it is so 6 or 3 dB is x2 depending on if it is voltage or watt. Then the curve is compressed compared to just showing the linear relation.
Old 22nd April 2018, 05:25 PM   #315
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
That's a good looking result, the response is flat where the drivers
meet at around -6dB. If you were to invert the phase of one driver
you should see a good null at that point.
Old 22nd April 2018, 11:15 PM   #316
I tried inverting one of the drivers but that just made things worse... I was thinking that your new xover might be able to provide compensation for the early drop off on the mid range as shown in the individual plots.
Or...... should I not worry about this dip? Just that I thought a fair bit of music detail would be contained in this 3500-5000hz range.
Old 23rd April 2018, 01:57 PM   #317
RogerGustavsson is offline RogerGustavsson  Sweden
You will need a more advanced crossover than the ones discussed here in order to rule out the irregularities above 2kHz.
Old 23rd April 2018, 02:57 PM   #318
chrisb is offline chrisb
There are several pages describing extensive upgrades to the HPD 385’s crossover
tannoy hpd 385 crossover upgrade - Google Search
But I think that much of the aberrations on these puppies above 2000 - 2500Hz would be require more correction along the lines of multiple parametric EQ to arrive close to “flat”response
Measured FR curves from Tannoy, and a couple of independent sources:
tannoy hpd 385 frequency response measurements - Google Search
Not a fan of the couple of factory builds that I’ve heard - Westminsters and Ardens, plus a custom built pair of 12” in “small” stand mounted, and 15” in fridge sized Churchill knock-offs. To each his own
like my mind, this space intentionally blank
Old 7th May 2018, 05:55 AM   #319
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Any updates on the kit arrival at the diyAudio store?
[ audioroot.net | hifibau.ch ]
Old 7th May 2018, 10:14 AM   #320
JOHNNYCR100 is online now JOHNNYCR100  Abu Dhabi
Default as above
Bump!
Pass Labs B4 crossover questionsHide this!Advertise here!
Pass Labs XVR1 crossover GRollins Pass Labs 62 25th November 2014 03:29 AM
Pass Labs goes out on the town Nelson Pass Pass Labs 62 27th May 2005 12:32 AM
New Pass Labs Website toshiba Pass Labs 36 25th August 2004 12:40 AM
pass labs sss Pass Labs 5 6th October 2003 06:23 AM
My opinion on Pass Labs and Mr. Pass (Nelson) himself b_online Pass Labs 11 21st May 2003 12:39 AM
