diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   400A Overheat ?? (http://www.diyaudio.com/forums/pass-labs/165755-400a-overheat.html)
ct1agi 25th April 2010 05:47 PM
400A Overheat ??
Hi everybody:
I recently have replaced the 2 big caps on the 400A PSU with two Epcos caps 22000uF, 100Vdc, 85șC. They match exactly the same diameter of the original, 64mm (Mallory 10000uF, 75Vdc, 85șC) and are a bit higher - 105mm vs 80 mm but no problems about it.
Since then the temperature of the heatsink seems to be higher...Even with the bias around 85mV, the temperature is considerably higher.
My concerns ar:
a) - something to do with the ESR of the new cap ??
b) - should I reduce the bias until the recomended temperature (45 / 50 șC) will be reached ??
Your advice / help will be appreciated.
Nelson Pass 26th April 2010 05:15 PM
If they are hotter than 55 deg C, then reducing the bias to
that temperature is probably a good idea.
:cool:
ct1agi 26th April 2010 07:34 PM
Thank you Mr. Pass.
I will do that.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
