There were two different goals that forces these ideas and concepts:
1) Only the adjust free power amp concerning bias adjust for idle current (self biasing - I know only the Quad 405 current dumping amp and some related topologies) 2) Additional no leaving the Class A operation and low idle current at the same time under all load conditions > 4 ohms (I know only Threshold and Mark-Levinson - Madrigal) Where I can find an overview of a wide range of commercial brands/ models so as topologies concerning this two categories (only push-pull topologies - not single ended)? Here patents/examples for this topologies: Patent US3995228 Madrigal Library: Adaptive Bias Patent US4160216 (automatic and dynamic/adaptive bias for classA under all conditions without external bias adjustment) Patent US4077013 (automatic Bias without external bias adjustment) Linear Tech. LT1166 chip (automatic Bias without external bias adjustment) Patent US5216379 (automatic and dynamic bias without external bias adjustment) http://220.232.128.43/audio/quad405/...J%20Walker.pdf (current dumping - ClassB without external bias adjustment) P. S. In this case also this threads could be of interest: New Class A, Super-A, Non-Switching : need a revival ? The Importance of Being Biased low-biasing or high biasing in Class-AB amps Last edited by tiefbassuebertr; 12th April 2010 at 10:14 AM. |
#2 |
I have I have got away with a design that uses a Vbe mulitplier but not on the heatsink so long as I keep the bias current low.
This works well with some designs. I also built a quasi and found that needed the bias transistor on the heatsink.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Today's commercial amplifier mainly use still for the idle current adjust the good known Vbe multiplier for the cumbersome manual adjustment procedure - I guess there are still over 90%.
I miss progress (not only in this case) even after such a long period of audio power amp experiences in Class AB. Also in the diy-aera I note this situation. |
#4 |
There is also the Huon/Dower patent (US6-630-865), which implements a form of `Non Switching Class B' bias. This technique is quite difficult to get stable, and definitely not suitable for beginners!
The Whise subwoofers of about 5 to 10 years ago used an inbuilt amplifier using this scheme. They won the Stereophile award for the best subwoofer. Unfortunately they are nolonger in production. |
#5 | |
Push-pull amplifiers http://www.audiotrends.com.au/docume...lse_Review.pdf http://web.archive.org/web/200807181....whise.com.au/ http://web.archive.org/web/200807191...nderFFX25.html |
#7 |
commercial products (brand and model number), that use adjust-free Class AB power amp sections still wanted (e.g. with the help of TDA7250/LT1166)
#8 | |
I was thinking of placing a red LED between the diode string for a stable constant voltage drop, and let the diode string do the thermal adjustment. Biasing amplifiers by hand is a night mare for manufactures in today's economy and business. I am thinking long way as well to find a cheap and simple way to avoid the manual adjustment. I think above suggestion would work well. With kind regards Bas |
#9 | |
But the purpose of a servo is just, that certainly values of tolerances, which are always present, have no effect on the quiescent current. An adjustment variable resistor must be still present. But after choosen the value for idle current through the output power stage this must be absolutely constant under all conditions (ambient temperature etc). By commonly circuit concepts (VBE MULTIPLIER) I must repeat the adjustment several times, that is horrible for me Last edited by tiefbassuebertr; 25th July 2010 at 10:03 AM. |
#10 | |
Another way to do it is with a micro controller which can read the voltage drop over the emitter resistors, and control a LDR in the bias string. With kind regards, Bas Last edited by Sebastiaan; 25th July 2010 at 11:35 AM. |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| Bias problem- 1 Socket shows extremely low bias! | otokomae | Tubes / Valves | 12 | 31st December 2008 10:01 PM |
| Dx Optimus is being prepared... dynamic bias.. Class A to AB | destroyer X | Solid State | 42 | 12th November 2008 12:54 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| Supressed bias amplifier, automatic variable bias system. | destroyer X | Solid State | 2 | 20th September 2004 10:24 AM |
| Page generated in 0.13283 seconds (84.37% PHP - 15.63% MySQL) with 11 queries |
