#11 |
The one and only
You can transformer couple the input so as to use a split supply with DC
coupled output - this way you can reject the supply rail noise, something you don't have to do when ground is the lower rail. Alternatively you would put one or two front end transistors to level-shift the input down to the Gate of the driver transistor - but then you have the original JLH circuit with three stages instead of two. If you had a very very quiet negative rail, you could make it work as is.
#12 |
Here is the circuit attached.
| Plh | Nelson Pass | Pass Labs | 192 | 22nd April 2013 07:57 PM |
| PLH vs ??? | MikeW | Pass Labs | 18 | 8th November 2005 02:06 AM |
