Old 28th March 2010, 05:03 PM   #1
Metric is offline Metric  Norway
Default 110 to 220volt conversion?
Anybody got schematics on converting a Pass Labs X250 from 110 to 220 volts?
What do you have to do? Is it a big deal?
Per Øyvind
NORWAY
Pass Labs x600, x1, ML Odyssey, Marantz SA-11S1, Syneristic Research cables
Old 28th March 2010, 05:19 PM   #2
event horizon's Avatar
It shouldn't be a big deal - no I should imagine that the mains transformer used has two 110V primaries wired in parallel for 110V use. To convert it to 220V you'll need to connect both primaries in series (start to finish, they need to be in phase to work properly). A change of mains fuse to approximately half the current rating of the fuse used at 110V would be handy for safety reasons.
Don't take this as gospel though as i'm not at all sure if there are other circuits that are powered from the mains side rather that transformer secondary.
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 29th March 2010, 05:26 PM   #3
The one and only
Nelson Pass's Avatar
The X250 was shipped with dual primaries, and so it can be
re-tapped to 240V, and possibly to 220V. Because of the
potential for shock and/or fire, the change should be done by
a qualified technician.
More specific information can be obtained from PL.
Old 30th March 2010, 05:32 PM   #4
Thank you very much!
Best regards,
Per Øyvind
NORWAY
Using 2N3055 and transformer to switch 220volt jacquesl Everything Else 3 6th December 2006 03:05 PM
Krell KSA50S conversion 110 to 230 Volts coronado2048 Solid State 21 4th December 2006 06:08 PM
Paradigm Sub SB-110 herm Swap Meet 9 23rd February 2006 12:21 AM
effects of 220 to 110 volts conversion? sachi Subwoofers 2 7th February 2005 10:06 AM
Page generated in 0.08669 seconds (71.49% PHP - 28.51% MySQL) with 10 queries
