Which amp should I built for my 16 ohm speakers?
Old 12th March 2010, 06:14 AM   #1
ajohn is offline ajohn  Hong Kong
Default Which amp should I built for my 16 ohm speakers?
My speakers' impedance is 16 ohm. Which Pass Labs amp should I build? I have some experience building DIY tube pre-amps but in fact I possess very basic electronics knowledge.
Old 12th March 2010, 09:24 AM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you didn't said what's efficiency of your speakers , but I presume that they're easy to drive ;
anyway - one of solutions is on first few pages of F4 thread - F4 with just one pair of output mosfets ;
F4 is "just" current buffer , so tube pre is welcome , with usual tube voltage swing
so - find latest F4 schematic ( probably is on First Watt site as pdf file ) , leave just one output pair of mosfets in place , and enjoy
if you have some more questions - just ask
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 12th March 2010, 12:22 PM   #3
flg is offline flg  United States
flg's Avatar
Probably not a bad idea But, in that case I would pump up the bias a little more Maybe 1A or so... Just my 2 cents.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 12th March 2010, 02:01 PM   #4
Zen Mod's Avatar
it really depends of nature of his speakers
in any case - valid and good note
Old 12th March 2010, 02:22 PM   #5
I don't know the sensitivity for sure but it should be about 95 db.
Is the F4 easy to build?
Old 12th March 2010, 04:36 PM   #6
flg's Avatar
Well, 95 is a good eff # for most people I acctually made a little mistake in my post "I" would actually try to run the output FETs in their most reliable/linear range. And to me that would be about 30-35W dissapation. 65C Heatsink temp max. Considering maybe 22-23Vds. 1.4 or 1.5A Iq. A 70W heatsink is not that difficult
There are other factors but... For instance, you can gain a bunch by insolated H.S. and Arctic Ice with no pads, mica etc. ect.
Old 14th March 2010, 11:42 PM   #7
Please tell me why a F4 is more suitable for my 16 ohm speakers rather than, say, the F5.
Old 15th March 2010, 12:38 AM   #8
Bill Fuss is offline Bill Fuss  United States
RIP
It isn't necessarily, mathematically speaking. A 16ohm driver pulls less current than an 8ohm and would like a proportionally higher rail voltage. You would be optimising the amp for that particular load and could do it by lowering the bias current simply by eliminating some output transistors. IMHO the F4 would be a better choice if your tube pre has enough voltage swing.
But that's just my opinion.
Which amp should I built for my 16 ohm speakers?Hide this!Advertise here!
Matching my 8 ohm amp to 16 ohm speakers. DocJDG Solid State 9 21st April 2013 12:57 PM
F3 With 16 ohm Speakers? TV Man Pass Labs 3 17th March 2009 03:08 PM
16 ohm speakers moreismore Chip Amps 2 1st January 2005 12:53 PM
GC for 16 ohm high eff. speakers? jlharden Chip Amps 5 29th October 2004 02:12 AM
Zen V4 and 16 ohm speakers selder Pass Labs 11 21st December 2002 03:13 PM
Copyright ©1999-2017 diyAudio
