A customer of me had buy used Aleph 5 for 1500 euros and compare it to a diy ZEN from an other guy - a diy project, supervised by me 10 years ago - go to
ZEN include active crossover without additional OP AMP for ultimate sounding PHL1230 For the aim of compare by the Aleph 5 user the integrated MFB high pass unit of ZEN was removed (see schematic). The loudspeaker of the user with Aleph 5 are fullrange versions (FOSTEX "FE 103E" inside in diy vented box from the old French magazine 'l Audiophile) Compare to high end AB amps like Accuphase the Aleph 5 sounds clearly better at low and mid level. But the ZEN again provides a spectacular increase of sonic quality in all respects compare to the Aleph 5 (see attachement of schematic and photos of this ZEN amp - unfortunately without pics of power supply - only similar transformers) What could be the reason? I guess, the reason could be the internal power supply and transformer by Aleph 5 and the not exist large bypass polyprophylene caps of 200 uF from Arcotronics in parallel to the present smoothing capacitors. Additional the enhanced filter characteristics through the highly oversized halogen transformers. If my estimate right, I am planning an outdoor power supply for the Aleph 5 in the same quality than that one of the ZEN with very large halogen transformers (redesign for lower voltage isn't a problem for me). Is my estimate wrong, the user must perform the same diy project of ZEN (much more expensive than external power supply for Aleph 5). What are your suggestions, what I should do ? The clone of the exist ZEN or an outdoor unit (power supply) for Aleph 5? Last edited by tiefbassuebertr; 11th March 2010 at 07:14 PM. |
#2 |
With full-range, I would think the zen is better suited. My many zen projects included one that was biased @ 4 amps/ch, powered by 1500VA 45V trafo with 350,000uF capacitance, it completely blew my diy Aleph 5 away with similar power supply, on my speakers anyway. 8m PS cabling sounds a bit like a hassle, if not detrimental. Over-build the PS on the zen, increase voltage and bias, done and done!!
-john |
#3 |
Interesting. Thank you for your advices. From which brand are your 1500 VA transformer and the 350.000 uF caps?
This was done causes certainly space conditions. The suited power supply of the mentioned ZEN are behind the bookcase cabinet on the opposite wall (far away from the audio components). |
#4 | |
#5 | |
By a newer ZEN project I use 4 pieces 47000uF/63V (3pc for power supply and 1 pc couple capacitor between amp + speakers) from this series: http://www.ftcap.de/downloads/elektr...009/GW2009.PDF one of the best exist caps for such projects I recommend still the 63V versions, even if only max 27V is present. |
#6 | |
The Aleph has no place with a single high eff. FR driver. On the contrary, the old Zen sure has, for obvious reasons. Sure it's easier to keep talking nonsense, than actually dealing with the facts. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#7 | |
I don't understand this:
And what means "obvious reasons" in your mind? by the way - you will note by study of the data sheet, that the FE103E driver isn't a high efficiency version. Last edited by tiefbassuebertr; 13th March 2010 at 12:09 PM. |
#8 |
The re-read John's explanation, and the articles regarding the topic, published by Nelson Pass.
Trouble is that you tend to insist looking for reason in religion. You're not going to find it there. No amount of fancy caps, resistors, or power switches, is going to change the topology signaure. Magura
#9 | |
But my (and some other) practical experiences contradict mostly these statements clearly. This means for me at the same time, that only ultimate quality by certainly devices (and necessary also perfect wiring management) may sound differences audible expose between different circuit topologies. If someone broke this rule (unfortunately, most often the case), nobody can say about sonic advantages and disadvantages by different circuit topologies. I don't looking for reason in religion. Only clear facts count for me. By the way - you recommend papers without precise references. Nelson Pass have a lot articles there http://www.passdiy.com/articles.htm Pass Labs: Articles And who is John? John Curl or John Linsley Hood ? and which paper? |
#10 |
This is getting interesting, we need more information
| Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? | tiefbassuebertr | Pass Labs | 17 | 9th January 2012 02:10 PM |
| ZEN include active crossover without additional OP AMP for ultimate sounding PHL1230 | tiefbassuebertr | Pass Labs | 6 | 19th October 2011 09:30 AM |
| Ultimate sounded Cone Tweeter Overview without Ferrofluid wanted | tiefbassuebertr | Multi-Way | 13 | 2nd September 2011 02:07 PM |
| OPA 627 Sounded very dull | golf_bht | Parts | 41 | 10th August 2010 10:31 AM |
| ultimate mosfets for aleph 4? | hifi | Pass Labs | 1 | 3rd June 2001 05:01 PM |
| Page generated in 0.13434 seconds (84.90% PHP - 15.10% MySQL) with 11 queries |
