Choice of driver for El Pipe-O Choice of driver for El Pipe-O - diyAudio
Old 10th June 2003, 09:10 PM   #1
Nicwix is offline Nicwix  Australia
Default Choice of driver for El Pipe-O
Can anyone provide info on selection of a driver for El Pipe-O ...
Edit: Oops, this should be in the Loudspeaker forum - reposted there - see Choice of driver for El Pipe-O
Old 11th June 2003, 06:58 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Maybe, but I noticed that El-Pipeo initially got more response
here than in Loudspeakers.
Old 14th June 2003, 10:50 PM   #3
Duck-Twacy is offline Duck-Twacy  Netherlands
At least follow the criteria for TL speakers mentioned here I guess
http://www.diysubwoofers.org/tls/
And measure the height of your ceiling
Is that all there is?
Old 16th June 2003, 04:40 AM   #4
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Default Oldies But Goodies.
Just this weekend I pulled my old Kef transmission lines out of the garage and gave them a birthday. (amazing the things that get done when in the sin-bin).
These cabinets are 900mm high by 450w by 450 deep, with a B139 mounted in the top left corner, and multiple internal panels to give a folded path 3 times the height of the cabinet.
I am using a Dod 18dB line level crossover, feeding 100Hz and down to the TL's via a big Panasonic amp, and 100Hz up going to an Amcron D-150 MkII driving a pair of Kef 8" 2 ways mounted on top of the TL cabinets.
This combo is around 450W total I suppose, and works bigtime.
Nicwix, if you go to the trouble of making TL's, I expect that you will find the results very worthwhile.
Nelson - For pretty impressive bass, try a listen to the 8 minute version of Madonna's "Nothing Really Matters" after about 4 minutes in.
On my system, the couch massages the kidneys and blurs the vision.
Eric.
I believe not to believe in any fixed belief system.
Choice of driver for El Pipe-OHide this!Advertise here!
Driver Choice and Maximum Output pjpoes Multi-Way 7 4th March 2009 02:02 PM
EXPERIMENT - Small driver in a big pipe/horn - does it need a sub? just a guy Full Range 31 18th September 2008 09:52 PM
tri-amped driver choice 13814044 Multi-Way 6 6th February 2008 06:37 PM
Help with driver choice. unitgain Multi-Way 5 2nd March 2004 10:18 PM
Choice of driver for El Pipe-O Nicwix Multi-Way 14 1st July 2003 09:18 PM
Copyright ©1999-2017 diyAudio
