F5 meets Buzquito
F5 meets Buzquito
Old 25th February 2010, 03:17 AM   #11
fab is offline fab  Canada
fab's Avatar
F5 meets Buzquito
Originally Posted by juma View Post
I tried using Hitachi/Renesas lateral MOSFETs in F5 but they lack transconductance and can not provide sufficient gain as drain followers without harming the sound.
Since they perform great as source followers it's obvious that another gain stage is needed between input JFETs and output laterals. ....
Schematic resembles Buzquito but feedback network is F5-like.....Here are the schematic and PCB layout (both open for discussion ) :
I had a "similar" idea almost 2 years ago...
http://www.diyaudio.com/forums/pass-...ml#post1518771
Old 25th February 2010, 08:52 AM   #12
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 meets Buzquito
yeah - world turns around in circles
DIY is jazz !!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 25th February 2010, 09:04 AM   #13
osscar is online now osscar  Latvia
osscar's Avatar
You should give the name for this amp -Fuzquito
My DIY so far: two Leach amps, Pass AB100, Pass F5, B1 buffer, Hiraga le monstre, two LM3875, LM1875, OPA549, 6C33C SE, GU32 PP, 6p3c-e PP, Marsh headphone amp.Phono - OBH-8se, Pacific RIAA, inDiscreet Phono, Whammy headphone amp.
Old 25th February 2010, 11:25 AM   #14
juma is offline juma  Germany
juma's Avatar
Originally Posted by njepitt View Post
So, did I get it?...
Yes you did - "same current" for the amp as a whole
Originally Posted by VladimirK View Post
Do you really need source resistors for output laterals ? With idle currents above 150mA the laterals balance themselves very good.
Without source resistord you'll have current hogging regardless of Id - that's how many good lateral MOSFET died...
Only insanely tight matching might get you rid of source resistors.
Yes, I remember that. I don't like the sound of JFETs with such a low Id. Second stage (with BJTs) is also not at all to my liking.
How did that project ended?
Old 26th February 2010, 03:47 AM   #15
fab's Avatar
F5 meets Buzquito
Default Fab-Four Amp
...Yes, I remember that. I don't like the sound of JFETs with such a low Id. Second stage (with BJTs) is also not at all to my liking.
Hi
I have increased the jfet Id to 5 times more than original (5 to 6 ma from what I remember). For the second stage I have used a BJT enhanced cascode.
It ended like this:
fab-fourpoweramp (fabaudio)
Old 26th February 2010, 04:02 AM   #16
VladimirK is offline VladimirK  Uzbekistan
Matching costs a lot, but I believe it is needed for sound quality, irrespective to current equalization. If laterals are so much different that die without source resistors, than sound will be so-so.
Old 26th February 2010, 12:07 PM   #17
juma's Avatar
It ended like this:
Nice
Matching is always nice, but it's not the thing that will per se make your amp sound great or bad.
Lateral MOSFETs have their distinctive properties but diyng from too much current is not what makes them exclusive - BJTs and HEXFETs have Pd max limit too.
Actually, you are saying that output devices which use source resistors can never sound good, right ?
Old 26th February 2010, 12:22 PM   #18
No, I only say that paralleled laterals tend to diminish an effect of dismatch between them, opposed to HEXFETs and BJTs, that tend to rise even a minor dismatch. Therefore HEXFETs and BJTs ALWAYs need source/emitter resistors, while laterals usually don't need them, except for probably a case of terribly dismatched pair. But in the last case sound will also suffer.
Old 26th February 2010, 12:53 PM   #19
juma's Avatar
No, I only say that paralleled laterals tend to diminish an effect of dismatch between them....
....laterals usually don't need them (source resistors)...
Not in my experience (2sk135/2sj50).
What laterals did you use to obtain such results?
Old 26th February 2010, 01:12 PM   #20
In my 50W Zen9 I use matched triplets of 2SK1058, total current 3,9A (1,3A and 40W per transistor), do not feel any problem.
F5 meets BuzquitoHide this!Advertise here!
LM4702 meets up with 6550's jackinnj Tubes / Valves 4 16th December 2007 11:04 PM
Old meets new but can this be solved? barchetta Pass Labs 4 11th March 2007 07:29 PM
The SACD Meets Tubes alexmoose Tubes / Valves 9 25th August 2006 06:33 PM
Old Meets New philipbarrett Tubes / Valves 3 22nd August 2005 12:03 AM
