X = bridged = push pull ? ...
Old 9th June 2003, 08:44 AM   #1
Bernhard is offline Bernhard  Germany
Bernhard's Avatar
Question X = bridged = push pull ? ...
* In the manuals of the Aleph3/5 Nelson states that single ended classA is better because in push pull classA, it's like two guys sawing with one saw, not achieving perfect coordination.
When building a circuit in X configuration, isn't that introducing push pull ?
* The Aleph 3 current source, is it dynamic or not ?
In the manual I can't find anything about that.
It just says 2A.
* Is it sufficient in Aleph to have idle = 2 * output current ?
If the load is very high impedance and the load current is max. 50mA, is it ok to idle at 10mA ?
* Wouldn't a single ended DIY op amp always be better as a chip just because of being single ended classA ?
The chip op amps are always push pull
Old 9th June 2003, 08:47 AM   #2
Freddie is offline Freddie  Sweden
Yes, the Aleph 3 uses a dynamic current source.
Old 9th June 2003, 08:50 AM   #3
Bernhard's Avatar
How much does the current change ?
Old 9th June 2003, 08:55 AM   #4
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
To answer part of your question, yes it is introducing an aditional factor but i'd be hesitant to really call it push-pull. Given that both ends are driven by N channel devices each in Single Ended configuration it's likely that we will do far less damage than the comparatively poor linearity of P vs. N channel devices plus when you consider the advantages of a balanced drive system, IMHO you end up quite a way ahead of push-pull amplification driving a single end of the load with the other end grounded.
- Dan
Old 9th June 2003, 09:03 AM   #5
Warp Engineer
On Holiday
AudioFreak's Avatar
most of the alephs are set at roughly 50% so idle current is approx. 1/2 of the peak current the circuit can deliver.
- Dan
Old 9th June 2003, 09:38 AM   #6
stefanobilliani is offline stefanobilliani  Italy
Moreover a push-pull is do with a single-ended signal wich drives a pair of non-inverting complementar devices .
Old 9th June 2003, 09:46 AM   #7
Bernhard's Avatar
The linearity of P-fets is not so good like that of N-fets ?
The Aleph have P-fets in the input stage
Old 9th June 2003, 10:36 AM   #8
Warp Engineer
On Holiday
AudioFreak's Avatar
P channel devices are generally about 1/10 as good as their N channel counterparts and even P channel devices that are meant to be a match to their N channel counterpart are often quite a long way off being a good match for the N channel devices. The input stage is low power and again is single ended so does not incur as much of a penalty as would be the case with having P channels in the outputs. The real problem is with push-pull stages as the linearity of N channel vs. P channel is quite different so apart from the crossover distortion, you get quite different linearity for either side of the wave.
- Dan
Old 9th June 2003, 10:57 AM   #9
Bernhard's Avatar
Thanks,
so can we say that the Aleph3 current source is basically biased 2A @ no signal
and
bias increases with signal to 4A @ full signal ?
Old 9th June 2003, 11:06 AM   #10
Warp Engineer
On Holiday
AudioFreak's Avatar
Originally posted by Bernhard
Thanks,
and
Yes that's approximately correct.
- Dan
X = bridged = push pull ? ...Hide this!Advertise here!
6T9 push pull Jaime Tubes / Valves 2 26th December 2007 04:14 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Push Pull bellx Solid State 3 25th January 2004 10:59 AM
push pull 845 audioman Tubes / Valves 5 30th August 2003 05:53 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Copyright ©1999-2017 diyAudio
