Old 5th April 2010, 03:19 PM   #41
P901 is offline P901  United States
Send a message via AIM to P901
Okay, for now a final followup.
Many thanks to the forum members for helping us through this
repair.
The amp is running fine, clear and powerful.
The photo shows the installation of an IXYS FRED rectifier, 1200v, 20amp
with the addition of Sprague .1uf Poly caps across the main power supply
capacitors
Thanks again for the support !
andrew
Old 5th April 2010, 07:32 PM   #42
R-K Rønningstad's Avatar
Hi, nice work !
I have a 400A myself. Which IXYS FRED did you use?
best regds
RK
Old 5th April 2010, 08:16 PM   #43
Good afternoon !
The rectifier we used was the IXYS VBE17-12NO7
If I recall it can handle 1200v at 19a.
Regards, andrew
Old 5th April 2010, 08:21 PM   #44
Good afternoon to you, too, and thank you so much.
The datasheet can be found here PartDetail
Seems I have to purchase one IXYS VBE17-12NO7!
/RK
Old 5th April 2010, 08:54 PM   #45
analog_sa's Avatar
capacitors
Something in the region of 10uF seems more appropriate for such large capacitors.
Old 5th April 2010, 09:00 PM   #46
Thank you for that suggestion,
we shall probably run the unit as it
is for a bit and then try the 10uf.
Thanks again ! andrew
Old 6th April 2010, 02:34 PM   #47
m2003br is online now m2003br  Brazil
Hi Andrew,
Congratulations for your succesful job!!!
The 400a deserves respect and a new chance to show how good it is!!!
Marcos
Old 6th April 2010, 04:08 PM   #48
Good afternoon Marco !
Thank you again for your hand drawn schematic !
Your drawing most certainly helped us understand the
layout of the unit.
Best regards, andrew
I want the best SQ sub I can get for under $400 gadgeteer123 Subwoofers 30 29th January 2010 07:05 PM
Threshold 400 a ress4278 Solid State 7 4th April 2009 02:03 AM
Threshold 400 A mjgoldstein1 Solid State 2 23rd January 2009 01:27 PM
Page generated in 0.08173 seconds (76.05% PHP - 23.95% MySQL) with 11 queries
