Old 20th February 2010, 11:24 PM   #1
simonov is offline simonov  Bulgaria
simonov's Avatar
Default Aleph L with potentiometer
Hello. Is it possible to use potentiometer at the Aleph L preamp output? What value should it be?
Old 22nd February 2010, 05:18 AM   #2
The one and only
Nelson Pass's Avatar
That would be the stock Aleph L. I also recommend an input
potentiometer specifically to avoid input overload, with the
output pot used for everyday volume control.
Old 24th February 2010, 04:37 PM   #3
simonov's Avatar
Thanks mr. Pass. I guess i should just buckle up and make the stepped attenuator. After all a serial one is not that hard to build.
Old 24th February 2010, 11:50 PM   #4
The one and only
Start out with a regular pot if you like. You can always
upgrade to the switched attenuator later, and then you will
get to hear the difference.
Which value of a potentiometer Alfetta87 Tubes / Valves 9 29th April 2008 12:56 PM
Looking for potentiometer skidave Parts 1 24th September 2007 05:26 PM
Aleph P1.7 output potentiometer Stefanoo Pass Labs 11 11th May 2007 06:56 AM
Need some help with potentiometer. mkapszewicz Tubes / Valves 6 29th November 2006 04:55 AM
potentiometer pass aleph 1.7 P270 Pass Labs 7 16th November 2005 05:28 AM
Page generated in 0.06800 seconds (80.99% PHP - 19.01% MySQL) with 10 queries
