Old 20th February 2010, 08:05 PM   #1
Default Aleph Current Source Mod
The Aleph series of amplifiers, First Wall Aleph J, Zen variations 2, 4, 9, my own variation LPTZen and countless other Pass inspired DIY amps all employ the 'aleph' active current source.
The effects of non-linearities in the transfer characteristic of the output transistors can be minimised by operating with high quiescent currents and a limited signal range. With push-pull amplifiers, it helps to ensure that both of the output transistors are driven equally.
In Zen V4, for example, a quiescent current of 2A is set by using a 0.33 Ohm sense resistor in the drain of the active load transistor. Part of the loudspeaker load current is sampled via a 0.235 Ohm resistor and fed into the base of the current controlling bipolar to modulate the active load current.
The effect of non-linearities in the transfer characteristic of the output transistors can be minimised by operating with high quiescent currents and a limited signal range. With push-pull amplifiers, it helps to ensure that both of the output transistors are driven equally. This is achieved by careful selection of resistor values:
In the case of Zen V4 for example:
R16 = (2 x R14//R15 x R6)/Ro
R16 = (2 x 0.235 x 1k3)/0.33 = 1k85,
( R16 is 1k8 in the first of the attached figures.)
There is a simpler embodiment which eliminates the decoupling capacitor and and loudspeaker current sensing resistor. In the case of Zen V4, open the second attachment.
In the case of LTPZen, Aleph J etc open the third attachment.
Old 21st February 2010, 02:38 AM   #2
bobodioulasso's Avatar
Do you refer to this?
Excellent SRPP power amp of MOSFET
I am building a modded Aleph J following this principle.
The fun is that has been posted some years ago but seems to have been unnoticed then. This came under the spotlight when the J2 was born.
Wensan has built a buffer recently, but may be you know the story.
In the Wensan design, there is one more resistor :R16 (Wensan) and no zenner.
What is the zenner for?
It is nice for me to see how to calculate R16 (yours) ...
What do you think about the Zen Mod post
FirstWatt J2
Old 21st February 2010, 03:01 AM   #3
Bigun is offline Bigun  Canada
Bigun's Avatar
I have the same the design under construction for an SRPP amplifier - I've seen this embodiment in many places although I don't have a list of references. You might find some related circuits under 'Gyrator' too which show the same thing. I have found that every variation I could think of is there on the Internet, or is a circuit that doesn't work.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 21st February 2010, 09:44 AM   #4
juma is offline juma  Serbia
juma's Avatar
Hi Allen,
nice to see you here again
I like your work very much and I wonder is there any progress on item 4. from your site ?
Cheers!
Old 21st February 2010, 07:21 PM   #5
Hi everyone,
1. Bobodioulasso
Thanks for the link. Wensan's approach is very similar. I searched the posts but missed this one.
I think I have got it about as simple as it can be. I like the fact that it is direct coupled, I like the fact that it is simple and versatile: Should you wish, you can even alter the balance between driver and load simply by adjusting the values of the sense resistors.
I dip in and out of the FirstWatt J2 post. Which particular issue?
Hi Juma
Must get round to posting the preamp details. Thanks for the reminder!
Old 21st February 2010, 08:19 PM   #6
After thinking more about it, i think Zen Mod says it wont work with the low Vgs of power Jfets. (The post I pointed at).
I have seen your website about the zenner clamp...I understand now.
In your third attachment, isn't a resistor missing from collector to base of T9, to set the CS bias?
Old 22nd February 2010, 05:28 AM   #7
The one and only
Nelson Pass's Avatar
It's not that it doesn't work, but you do have to consider the
performance of the npn bias device at lower Vce voltages.
Old 22nd February 2010, 09:16 PM   #8
T9 doesn't seem to need a bias resistor. I think the 1nF capacitor is sufficient to kickstart the feedback. Thereafter R16 is sufficient.
I could see no reason why you could not substitute the IRFP044n's for jfets, logic level mosfets, darlingtons or even standard bipolars. The feedback controlling bipolar only needs a few milliamps of collector current and at these levels, Vce will saturate at around 30 to 50mV. In fact I have just breadboarded the aleph css (the relevant subcircuit, not the complete amp) using a BC639 for the feedback controller and an old TO3 bipolar of dubious vintage as the current source. With these devices, the collector-emitter voltage of the feedback transistor was measured at ~1.3V and seemed to work fine!
With jfets or mosfets there is no gate current to speak of so you could reduce the collector current below the 5mA or so it currently uses. At the risk of offending some people, nice linear bipolars/darlingtons may worth exploring!
Old 23rd February 2010, 01:26 AM   #9
Bigun's Avatar
Allen,
no offense at this end, I like the idea of using bipolars - because I have quite a few in my junk box and no FETs!
I am in the process of building a version of this current source into a simple amplifier with all Bipolars so I'll let you know how it goes (although it's subject of a different thread at this point).
p.s. I like your triac protected psu design, leverages nicely from the cap multiplier.
Old 23rd February 2010, 08:24 AM   #10
If you do try it with bipolars or darlingtons, then the positive temperature coefficient may be an issue. With mosfets, the transconductance is degenarative, but with bipolars the HFE is regenerative. Having both output transistors on the same heatsink will no doubt help but you may need to put a capacitor in series with R10 in the 3rd diagram.
The ltp current source is fairly temperature stable and the output drift is minimal with the mosfet output design. Alternatively use a 2nd aleph css on the output driver transistor as per the Aleph amps.
ALEPH Current Source Info annanberg Pass Labs 0 4th October 2006 07:48 PM
Aleph-type current source, but source follower this time tschrama Pass Labs 4 29th July 2005 12:55 PM
Aleph current source: huh? pixpop Pass Labs 5 9th April 2005 06:16 AM
Aleph Constant Current Source RobPhill33 Pass Labs 2 20th February 2003 02:54 AM
Aleph Current Source Vince Maida Pass Labs 2 2nd April 2002 12:56 AM
Page generated in 0.15293 seconds (85.11% PHP - 14.89% MySQL) with 11 queries
