Buffer Preamp with Shunt PS
Yes, i use varieties of the JLH buffer. One i made uses darlingtons in the output stage. It is based on feedback, so distortion is really low. Still the best sounding buffer i made so far is open loop. I call it the Hawks buffer. It needs a lot of N and P-channel Fets so it is a bit expensive to make. Because it is very hard to find 2SJ74 Fets right now i have moved on to bipolar buffers recently. A sound comparison is in the making.
JG_Buffer based on Hawksford-Design
This is the best buffer I ever heard.
We have used the JG-Linestage and built several buffers in front
After listening test this is the result
1.J G Hawksford-Buffer
2. Kaneda-Buffer
3. JLH-Buffer
4. LME49600
The sound of the JG Hawksford buffer is marvelous!!
You can build it with only one pair of J-fets. it depends on the load you want to drive.
I am very courious for the bipolar design
Kind regards
Sam
I have been told some years ago that KP903A are used in industrial communication equipment at Vds near 40V (datasheet tells 20V only). I assembled various amps based on KP903A during last three years, also with Vds=40V operation conditions. Everything is stable.
Just today I tested randomly chosen KP903A as a current source, started to increase Vds with observing Id current. Increased Vds up to 50V, the part still keeps stable Id. Decided not to risk more and not destroy a part.
The Bear (member of this forum) tested these parts by curve tracer, and confirms that 40V is not a problem for KP903A.
I would also like to mention, that jFET quality criterion (transconductance / Ciss) is almost order of magnitude better for RF part KP903A rather than for most popular Toshiba's 2SK170 jFET.
