Old 11th February 2010, 08:52 AM   #1
Rick NL is offline Rick NL  Netherlands
Default B1 PSSR Question and idea
Dear Nelson and all others.
I have a question about the PSSR of the B1.
Will the PSSR of the positive side with the drain of the gate-follower be higher or lower than that of the CCS at the ground?
When the CCS yeilds a higher PSSR would it than not be benificial to move the Gate-follower to ground and have a CCS in the Powersupply?
This can be accomplished in two ways, both keep the CCS with an N-Channel FET, the Follower can be either N-Channel with inversed PS or with P-Channel with the normal negative ground.
Comments please.
Rick
After all it's the music
B1 Preamp Grounding Question jonsmith Pass Labs 8 18th November 2009 11:49 AM
B1 layout question peranders Pass Labs 3 15th October 2009 09:10 AM
B1 pre earth safety question (newbie) scorpio1 Pass Labs 2 16th June 2009 04:30 PM
scanspeak tower idea/question i4gotmyid Multi-Way 5 21st August 2007 09:07 PM
TDA2003 hum ¿PSSR problem? sync40 Chip Amps 3 2nd November 2005 06:40 AM
Page generated in 0.07232 seconds (65.86% PHP - 34.14% MySQL) with 11 queries
