Old 7th February 2010, 10:10 AM   #1
djk is offline djk
djk's Avatar
Default Chokes for SE class A
Does this sound like a reasonable idea to try for the constant current choke on a single-ended class A amplifier?
"there is a trick that can actually increase the inductance and mostly cancel core saturation. Take two I-cores, stack them end to end, the closer the better (epoxied together for long term use is best), and run them in reverse magnetic polarity while in series. This can allow you to use a smaller initial value of inductor, and keep core saturation to a minimum. For instance if your goal is 10 mH, you don't need two 5 mH inductors, but more like two 3 to 4 mH inductors, the exact value depends on how closely coupled the cores are.
If you had inductors rated to handle say, 5 amps each, when configured in this manner, they might be able to take 15-25 amps or so, depending on how well matched and positioned the cores are.
Ideal implementation has two bobbins on a single long laminated core, no air gap losses then." (Jon Risch)
"big thanks Jon , I found two 1mH Madisound steel core inductors and twisted the leads to put them in series. I'm not sure if I got all the permutations available as I didn't change the lead connection - but did change one core's orientation.
Inductance measured ~2.1mH with cores spaced, 1.75mH with in one butted position, and 4.15mH in the other. Did I leave out something as one position was double the inductance? Out of the conditions tested which one is the preferred?" (Fred I)
Candidates for the Darwin Award should not read this author.
Old 7th February 2010, 10:46 AM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Well, you need much higher inductance. 2 x 80mH is barely enough.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 7th February 2010, 11:01 AM   #3
This has been talked about before. Nelson even has an example of this in the ZEN 7
article found at Passdiy.com. But as Magura pointed out for good base responce you
will need a large inductor 50mh might do for use in a midrange amp. And large inductors tend to be hard to find and expensive!
Old 7th February 2010, 11:18 AM   #4
Magura's Avatar
Here is a little reading to start you out:
Choky Susy F3 for LU1014's
Magura
Old 7th February 2010, 06:34 PM   #5
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
that's sissy amp ; it demands 20R NTC to salvage local area power ring , during starting
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
Old 7th February 2010, 07:16 PM   #6
Magura's Avatar
Hey, it's not a real amp, if it doesn't dim the lights a bit at startup
Magura
Old 7th February 2010, 11:14 PM   #7
djk is offline djk
djk's Avatar
I guess I should have given more detail, the question was really about the winding technique and core saturation in a DC application.
Do any of you know the answer to that?
"Well, you need much higher inductance. 2 x 80mH is barely enough."
Thanks, I think most people can figure that out.
How much inductance do you think is actually needed for a high frequency amp (400hz and up)? How about for a VHF amplifier (4Khz and up)?
Old 7th February 2010, 11:57 PM   #8
I would expect for 400hz up a 20mh choke would work and for 4kup a 2mh choke.
Aswsuming a 8ohm speaker. For these values I would use aircore chokes. 2.5 lbs
of 16 gage magnet wire using a 1/2" core .75" long will give you about 20mh.
Old 8th February 2010, 06:42 AM   #9
Magura's Avatar
That is good advice Woody.
I have experimented with cored inductors, and DC seems to cause issues.
Magura
Old 8th February 2010, 08:05 AM   #10
miklos is offline miklos  Canada
Could you please describe the issues closer?
Thanks.
miklos
Best Class A SE amp cka3o4nuk Solid State 0 19th February 2009 11:34 AM
Can this really be Class A & SE? WithTarragon Pass Labs 5 2nd June 2008 09:45 PM
SE Class-A developing bogdan_borko Solid State 22 20th February 2007 02:39 AM
SE Class-A headfone redrabbit Solid State 0 5th October 2006 05:27 AM
2 class A SE amplifiers: need suggestion! claudio Solid State 14 25th March 2002 10:47 PM
Page generated in 0.10485 seconds (80.65% PHP - 19.35% MySQL) with 11 queries
