Old 11th February 2010, 08:53 AM   #41
flg is offline flg  United States
flg's Avatar
I experimented with a Hammond Mfg 195T5 rated @ 100mH at 5Amps w/.64ohm DCR they have a small Air Gap. About $50.
Hammond Mfg. - Chokes & Reactors - Heavy Current (195 Series)
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 11th February 2010, 09:17 AM   #42
Tyimo is offline Tyimo  Hungary
The choke in #18 looks like an AC powerline choke, and may not do well with a bunch of SE class A idling current. If anyone has an idea (or can link to a discussion) of how to evaluate an AC choke for this use, please share it with me.
Yes, it is.
Carpenter wrote that this choke with airgap gives 50mH, that would be enogh for your 400Hz 16R loudspeaker. The choke would give you 125R
Tyimo
Old 11th February 2010, 11:42 AM   #43
djk is offline djk
djk's Avatar
He gave no data as to the source, and says that the minimum order is $1K, and then they must have an airgap cut?
Unless I get some more suggestions, I think the 70mH $27 Signal CH-2 choke from Digi-Key will be what I try.
Candidates for the Darwin Award should not read this author.
Old 11th February 2010, 03:15 PM   #44
Paper mache horn fabricator
carpenter's Avatar
In the 50 mH unit, I don't think they actually cut an air gap--the I E plates are stacked with no interleaving. Instead, they have E stacked on E and I stacked on I, and separated a hair.
The laminations they used on my choke air very thin.
All in all, I hear very little difference between the two types of choke. When I spoke with Hammond's engineer, I asked for a high quality product at a reasonable price. It seems they delivered the goods.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 11th February 2010, 03:26 PM   #45
carpenter's Avatar
It just occurred to me: the amps I use this choke with have a balanced power stage. The DC factor cancels out.
Best Class A SE amp cka3o4nuk Solid State 0 19th February 2009 11:34 AM
Can this really be Class A & SE? WithTarragon Pass Labs 5 2nd June 2008 09:45 PM
SE Class-A developing bogdan_borko Solid State 22 20th February 2007 02:39 AM
SE Class-A headfone redrabbit Solid State 0 5th October 2006 05:27 AM
2 class A SE amplifiers: need suggestion! claudio Solid State 14 25th March 2002 10:47 PM
Page generated in 0.08425 seconds (76.04% PHP - 23.96% MySQL) with 11 queries
