(x) (x) = N_p
(x) (x) = N_p
Old 5th June 2003, 04:53 PM   #11
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
It's always a pleasure to hear happy people freak out!
Pics will be needed soon… very soon. We hardly can wait to see that babe.
/Hugo
Old 5th June 2003, 05:30 PM   #12
roddyama is offline roddyama  United States
roddyama's Avatar
Hi Ian,
Super job on the JBL's. They look fantastic.
Can't wait to see some more amp pics.
I love your discription of the bass reproduction. The deep bass should be felt and not heard.
Rodd Yamashita
Old 5th June 2003, 05:38 PM   #13
grataku is offline grataku  United States
What's the point of using these ridiculously low rails and insanely high currents to get a few dirty watts, as it turns out by actual measurements? Double THD when going from 12 to 15 v rails, as I recall.
-Do you have speakers with 1 ohm impedance that you need to circulate 10 amps per channel?
-Do you plan to double your amp for use as an arc welding station?
For the power you are going to be able to get out this circuit you can, even by very conservative standards, use one mosfet per side, it cuts down on the mosfet capacitance, if you want to get even fancier you can use a high transconductance mosftet like the 044 that should sound better ( in principle).
I had the same criticism for the x-zenlight with 12v rails. The high currents put a much higher demand on the PS in terms of handling the ripple, heating on the rectifiers, transformer impedance and on and on and on.
free your mind
Old 5th June 2003, 05:42 PM   #14
Macka,
I respectfully bow to your speakers
Old 5th June 2003, 06:16 PM   #15
nobody special is offline nobody special  United States
nobody special's Avatar
Yeah, but you're still completely wrong on that one! The high currents needed are for even a 6 ohm load without current limiting... which most 8 ohm speaker get down to.
Simulate it or build it and see for yourself!
Free YOUR mind.
The aleph sources in the X make a big difference. I am actually planning on using 1 device/side in my AlephX, because of everything you mentioned. No need for more. If I were going to be using these with my 4 ohm MTMs, however, I would up the current to be on the safe side. Why limit the output capability when you have the voltage headroom (especially when you are talking about a low powered amp... it would be different if you had a clean 100 watts into 8 or 4 ohms). It all depends on your speakers.
Steve
Steve
Old 5th June 2003, 06:26 PM   #16
MikeW is offline MikeW  United States
MikeW's Avatar
It sounds better when you put more current through it.
I ran my X at 10 amps a side for a while. It sounded great but I had to keep resetting the breaker when I turned the microwave on.
MikeW
Old 5th June 2003, 06:29 PM   #17
stefanobilliani is offline stefanobilliani  Italy
Originally posted by macka
Some subjective view before the neighbours crack it,
The A Aleph appears to hightlight tranisents very well,
Any percussive sounds...Caroline's drum kit...its so real you can fell the snap of the snare, the crack of the kick.... its in the room surrrrrrrrrrrreal.
And Where are those 18 inch woofers.........they disppeared...the distinction between felt and heard bass is like a tremor and shock wave.
The the harder I push the better she performs without effort.
Ian '
Hey macka , what a view!
The thing that more of all impressed me is the complete coherence of the musical articulation: I play(back) the accordion on some of my favourite titles and it seems to be there together with the players in the room
.... but I'm for more voltage rails than +-15v.
Old 5th June 2003, 10:03 PM   #18
macka is offline macka
macka's Avatar
O'kay,
Seriously it is fun, but it ain't no woman . (I'm am getting the odd jealous email from a woman somewhere in the USA so I better cool it) Muhhahahahahahh
The box will be made tomorrow.
I am already thinking about retro Aleph 2, but that will mean a few more comparisons.
Ian
Old 6th June 2003, 02:11 AM   #19
Free YOUR mind.
Steve
Dude, do you really need 10 amps at 13v to get 20 tiny watts? I don't want to get into another argument about sims vs actual circuit but to put it in prospective, Nelson biases his xa200 at 8 amps with 30volts rails.
Old 6th June 2003, 02:46 AM   #20
nbaula is offline nbaula
Hi! Ian how does this amp compare with your'e Aleph two.
(x) (x) = N_pHide this!Advertise here!
Copyright ©1999-2017 diyAudio
