THRESHOLD CAS-2 poweramp.
Old 31st January 2010, 04:22 PM   #11
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Originally Posted by Zen Mod View Post
brianco - seems that you're one lucky bstrd
(NB that I didn't say that you don't deserve that )
But first, JamesBrennan4 & tiefbassuebertr:
That is excellent info. and enough for me to take a risk! ( I actually have a 1.5K isolation Tx anyway, but I dont like all that extra magnetism, cabling etc.) Thank you all for your kind trouble and input.
ZM: Send me US$ 250:00 and I will send you an Irish Luck Charm.....but I will have drunk the black stuff - just to save on post stamp cost you understand!....I am almost finished assembling my kitchen system! Just need a decent CD transport and a phonostage!
Old 31st January 2010, 05:35 PM   #12
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
If for the primary winding at least three wires, you can check the DC resistances for it (Please disconnect from main connector). You must find then two different values of DC resistance. The highest value must be approximately twice than the lowest value.
If you have more than three wires, means this more selected voltages are possible (e. g. 110-115-220-230VAC)
Use in this case the highest possible value for your main voltage (now all primary windings in series).
Check all this without the other stuff - i. e. only transformer without connected secondary winding.
If for the primary winding only two wires, I assume, you have transformer for only 110-115VAC
Old 31st January 2010, 05:53 PM   #13
brianco's Avatar
tiefbassuebertr
Again, many thanks. I hope to have the amp here within a few days and will report back on my findings and also give my opinion of the sound.
Old 21st August 2011, 06:30 PM   #14
runboy is offline runboy
Originally Posted by Nelson Pass View Post
Here's what I've got:
All,
I just picked up 2 CAS2.
It doesn't have anything on front either but these are made to be mono amps with 1 circuit board and 1 transformer but with 4 large capacitors.
The back is still the same CAS2 marking but the input and output are joint.
No serial number.
Are these monoblocks specially built?
The logo on front says customer series
anyone know? These are in Silicon Valley.
Old 26th February 2012, 08:49 PM   #15
shriekback is offline shriekback  United States
Hi everyone,
So I have a near perfect CAS2. I have changed all the caps out, including the main PS caps, and it sounds brilliant and has worked without a hitch for a couple of years. Unfortunately, however, just recently the right channel of the level meter has stopped working properly with all the LEDs lit up. The left channel, and the amplifier itself, are still working properly.
Would anyone here have any tips as to what part has gone bad? Is it an integrated chip of some kind or a discrete part? If the former, might it or some equivalent still be made?
Thanks and best regards!
Old 26th February 2012, 10:27 PM   #16
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
look in Papa's pub's thread
Papa's Pub's
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 26th February 2012, 10:34 PM   #17
brianco's Avatar
My seller withdrew! He then pushed the price wanted up into the stratosphere. I didn't buy it...but it was eventually sold. I'm now actually having to build an amp.
Old 6th March 2012, 08:16 PM   #18
coolnose is offline coolnose  Europe
brianco,
just wondering if you don't mind... what did the seller ask for after his withdrawel from the auction ??
Max
Old 6th March 2012, 11:25 PM   #19
brianco's Avatar
It was 700.00 (UK) which was too much!!! This was double the previous fully agreed figure.
Old 6th March 2012, 11:44 PM   #20
that hurts indeed... not saying the amp is not worth it, but the behavior of the seller is more than "cheap" ...
THRESHOLD CAS-2 poweramp.Hide this!Advertise here!
Threshold CAS 1 thistlehd Pass Labs 18 12th July 2017 09:45 AM
Looking for Creek CAS 4040 Schematic truenorth Solid State 2 18th February 2009 12:51 AM
Llano CAS 300 Penguin Solid State 0 27th September 2008 04:56 PM
Wait, do I finally understand the CAS? keantoken Solid State 18 5th August 2008 11:48 AM
