Solid State Replacement of Ribbon Transformer?
Old 27th January 2010, 08:01 PM   #1
tmblack is offline tmblack  United Kingdom
Default Solid State Replacement of Ribbon Transformer?
Nelson,
Can we design a FET or bipolar preamp for a ribbon microphone with low noise, wide bandwidth and superior sound to a transformer?
why do ribbon microphones manufacturers use transformers but MC cartridge owners generally use a MC preamp?
Thanks in advance
Tom
Old 27th January 2010, 11:58 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I don't have experience with ribbon microphones, but I
can assume that one issue is the noise of the environment,
and broadcast applications of ribbons probably want to
avoid that.
To better answer the question we would need some data
on the output characteristics of the microphone.
Old 28th January 2010, 01:28 AM   #3
I have more experience with ribbon speakers than ribbon mics myself, but I will try to design a circuit for it.
Take the specs for an Apex 210 ribbon mic.
That mic has an output impedance of 220 ohms, and let the transformer have a 1:27 ratio. That makes the ribbon impedance 0.3 ohms.
The rated output is -55dBV, 17.8mV at the transformer, or 66uV at the ribbon.
Would feeding it directly into an OP-AMP configured as a I-V converter work?
Tom
Old 30th January 2010, 08:45 PM   #4
I think I keep the transformer and then I'll need a mic-preamp circuit with a gain around 60dB.
How does a three 2N4401 transistor common emitter single ended circuit sound?
Tom
Old 31st January 2010, 12:08 AM   #5
The one and only
I would be inclined to try 2SK170's in a Common Gate circuit.
Old 31st January 2010, 04:49 PM   #6
bear is offline bear
expert in tautology
bear's Avatar
Noise can be an issue, as in device noise and circuit hum+noise - the transformer is a way to get the desired signal above the noise floor. Otoh, there are some commercial ribbon mics, iirc, that use FET or similar front ends... at least this is what the neurons seem to be retrieving at the moment.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Solid State Replacement of Ribbon Transformer?Hide this!Advertise here!
What Solid State Amps with Output Transformer do you know of? Onvinyl Solid State 27 27th April 2010 10:41 PM
Transformer output solid state lumanauw Solid State 34 3rd April 2007 02:14 PM
The Solid State Wiki - Your solid state reference guide Jason Solid State 0 25th June 2002 05:26 PM
Copyright ©1999-2017 diyAudio
