Old 25th January 2010, 11:34 PM   #1
Nikolas Ojala's Avatar
Question Why FET amplifiers?
Nelson Pass, why do you favor field effect transistors over bipolars in your audio amplifiers? Is there some special reason that lead you to use MOSFET and JFET in your amplifiers?
All distortions are not equal.
By the way: I hate overuse of acronyms.
Old 26th January 2010, 06:39 PM   #2
bear's Avatar
I'm not Nelson Pass, but my response is that JFets have a few advantages over bipolars:
- self biased with nothing on their gates
- triode like curves
- different spectra of distortion from bipolars
- different clipping characteristic than bipolars
- typically low noise
...others will likely suggest other factors as well
oh - they "sound good".
_-_-
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 26th January 2010, 07:48 PM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
sole reason - jfets are generally more expensive than bipolar counterparts , so Papa can write bigger number on price tag .
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 26th January 2010, 07:57 PM   #4
flg is offline flg  United States
flg's Avatar
He also has produced many single or 2 stage designs and although bipolars have enough gain compared to FETs, they also require base current effectively lowering input impeadances very often requiring an extra stage. Simplicity is usually better.
In the output stage, it is my experience that MOSFETs have more reliability and rugedness without the second breakdown, thermal runaway etc.
Oh, I'm not Nelson either.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 27th January 2010, 04:03 PM   #5
The one and only
Nelson Pass's Avatar
I used bipolars for the first 20 years of my work, but the
FET parts kept getting better, and ultimately they were a
better fit for the types of amplifiers I like to make.
If I didn't have them, I would work with bipolars.
Old 27th January 2010, 04:13 PM   #6
Originally Posted by flg View Post
In the output stage, it is my experience that MOSFETs have more reliability and ruggedness without the second breakdown, thermal runaway etc.
second breakdown under another name often occurs in MosFETs. Thermal runaway in vertical MosFETs afflicts them just as much as in Power BJTs.
regards Andrew T.
Old 27th January 2010, 07:15 PM   #7
Thumbs up Thanks
Thanks.
The other answers were interesting too.
Old 27th January 2010, 08:07 PM   #8
CBS240 is offline CBS240  United States
CBS240's Avatar
'Second breakdown' is not quite as limiting in mosfets wrt thier SOA. Thermal runaway is not quite as intense because of the limited transconductance of the mosfet compared to BJT, but still results in the same outcome.
All the trouble I've ever been in started out as fun......
Old 27th January 2010, 08:16 PM   #9
tmblack is offline tmblack  United Kingdom
I understand germanium transistors have less Vbe =0.3V, but do germanium transistors have smoother turn on as well?
There are lots of Russian Ge transistors that some say have very little leakage.
Perhaps, if they are more linear than Si types then there could be a comeback for them.
Tom
Old 29th January 2010, 01:25 PM   #10
bear's Avatar
Ummm... no.
Many Mosfets have a negative tempco until some threshold is reached beyond which they no longer can "turn off" on their own, and only then does thermal runaway occur.
Afaik, there are NO bipolars that exhibit this characteristic. Name one if there are Andrew.
All power circuits that use bipolars that produce substantial heat - like a power amp - include external devices to reduce the bias to prevent runaway. The typical Mosfet output stage does not.
_-_-bear
_-_-bear
Is this FET good to use into audio amplifiers? destroyer X Solid State 18 14th February 2009 05:43 AM
Threshold FET 10/pc Phono Stage Preamp Schematics aka FET 10pc, FET-10pc, fet ten/pc krellkraver Solid State 1 8th February 2007 03:05 PM
Fully complementary FET-in FET-out design Bensen Solid State 36 7th January 2006 09:21 AM
FET/BJT hybrid amplifiers angel Pass Labs 6 19th June 2004 02:37 AM
Yikes!! FET Substitution? Could use some FET Guru's here... EchoWars Solid State 15 9th February 2004 07:08 PM
Page generated in 0.11738 seconds (78.69% PHP - 21.31% MySQL) with 11 queries
